Forum: FPGA, VHDL & Verilog Lattice iCE40-HX8K Board - UART
Author: Zumby (Guest)
Hello,
I have the following verilog code for my Lattice iCE40-HX8K Board:
uart.v:
module uart(input clk, output TXD);
reg [3:0] count;
reg [9:0] data;
reg z;
initial begin
data[9:0] = 10'b1000000000; // Startbit = 1, Stopbit = 0
z = 0;
end
always@(posedge clk)
begin
  if(count == 1250) //9600x per Second (1250) = Baudrate
    begin
      count <= 0;
      TXD = data[z];
      z = z + 1;
      if(z == 10)
        begin
        z = 0;
        end
      else
        begin
        end
    end
  else
    begin
      count <= count + 1;
    end
end
endmodule
For receiving the UART-Data I use gtkterm under Ubuntu 14.04.
I have set the baudrate in gtkterm to 9600.
If I now program my FPGA with the code I receive once per programming a
hex "00" (irrespective of the 8 usage-bits).
Can anybody give me a hint what is wrong?
Thank you for your support.
Sincerely,
Zumby
I've know fixed two problems:
1. count has to be at least 11 Bits wide to count to 1250
2. z has to be at least 4 Bits wide to count to 10
3. Removed non-blocking assignments (<=)
The code know looks like this:
reg [10:0] count;
reg [9:0] data;
reg [3:0] z;
initial begin
data[9:0] = 10'b0010100101; // Startbit = 0, Stopbit = 1
z = 0;
end
begin
  if(count == 1250) //9600x pro Sekunde (1250) = Baudrate
    begin
      count = 0;
      TXD = data[z];
      z = z + 1;
      if(z == 10)
        begin
        z = 0;
        end
      else
        begin
        end
    end
  else
    begin
      count = count + 1;
    end
end
endmodule
I am now receiving an endless chain of "J" (like in the attachment).
But if I take a look at the data bits inside "data":
01010010
I should receive a ASCII "R".
My question is now why I am getting a "J" instead of an "R"?
Can anybody give me a hint what might be wrong?
Thank you a lot :)
Sincerely,
Zumby
Author: Antti Lukats (xilant)
The solution solves in 10 seconds if you have FAR commander installed:
1) create new file, readme.txt
2) type RJ i that file
3) close file
4) press F3 and F4, to get HEX view
52 4A
you may have to write it down in binary to see the that the LSB-MSB
bit order is wrong, reversed
0101 0010 Letter R
after bit reversal
0100 1010 Letter J
stay
DIPSY.COOL
you are on right learning path..
>     begin
>       count = 0;
With this your baudrate has the "usual" deviation of 1 clock:
Your count counts from 0 to 1250, what are 1251 steps. To count 1250
steps you must count from 0 to 1249.
You may say I'm splitting hairs, but thats a systematically problem.
Maybe tomorrow you want to design a counter for 5 clock cycles. And then
the deviation of 20% is significant...
Author: Lattice User (Guest)
This is a bad idee.
General guidelines are:
Use blocking assignments in always blocks that are written to generate
combinational logic.
Use nonblocking assignments in always blocks that are written to
generate
sequential logic.
For a discussion why see for example:
http://www.ece.cmu.edu/~ece447/s13/lib/exe/fetch.p...
Author: Alex (Guest)
I'd recommend you use constants that have the same amount of bits as the
registers/wire that you are assigning to:
    counter <= counter + 11'd1;
    z <= z + 4'd1;
    if (z == 4'd10)
@Lothar Miller:
systematically is an adverb, you have to use an adjective to modify a
noun (problem).
  • [vhdl]VHDL code[/vhdl]
