Forum: Analog Circuits Valve Amplifier - Röhrenverstärker
von Jubei K. (joobei)
Hello everyone,
I am interested in buying an entry-level valve amplifier. I don't have
much requirements in terms of power. The room is not so big and I will
be sitting 2-3m away from the speakers. I want to connect my computer
for listening to music (losless, high bitrate jazz/soundtracks/world
music) and to watch movies. Low-mid volume, nothing loud.
Could somebody plese recommend a pair of valve amp and speakers that is
a good match? If that's not possible then just the valve amp.
Many thanks in advance,
Jubei
von Alex R. (Company: None) (rybin87)
Hello. Your needs may be satisfied by a single-ended amplifier. One of
the most common valve is EL84 (3-4 Watts of power), also it is a good
sounding one. Why not to look simple schemes with this valve? Valve
amplifiers are quite picky about speakers. Mostly they like full-range
speakers (one driver).
: Edited by User
> One of
Hello Alex! Thanks for your post. By "scheme" you mean find an amp that
uses this valve? By full-range speakers you mean a speaker that has a
wide frequency response? Apologies for the simple questions but I'm a
bit of a noob.
Thanks in advance.
You're welcome.
1. Yes, you can find many amplifiers that use this valve. To get the
most from valves, all the parts of an amplifier must be rather high
quality.
2. Yes, that's right.
: Edited by User
All my research so far brings up DIY kits and honestly I just want to
buy an amp.
1. Are there any manufacturers that sell pre-built valve amps based on
the EL84 at reasonable prices?
2. How would I go about matching an amp to speakers?
von voltwide (Guest)
"scheme" stands for "schematics" or "circuit diagram". Wideband or
full-range means a single speaker as opposed to a 2-way or 3-way system.
von luhe (Guest)
Some volume potentiometers in these KITs tend to fail after a while.
Also you need to select a good output transformer. I'm not sure that
modern stuff is good, while not being expensive. Maybe you should find
old audio-transformers from a good tube radios - correct me, if i'm
wrong.
: Edited by User
Thank you all for the great advice but as I noted earlier, I am not
looking for a kit. I want to buy a ready-made amplifier. One that has
warranty etc.
von peda (Guest)
You may look on old high class tube radio schematics.
E.g. the RFT radio "Beethoven" has an excellent sound.
I owned it as a schoolboy for 20,-M (former GDR bucks).
It has separate output stages for bass and treble, because it was easier
to make transformers for a certain frequency in opposition to full
range.
Also the tone regulator schematic works good.
Because the AZ12 was broken, I soldered into the AZ12 socket two
1000V/1A Diodes with 100R in series.
Following the schematic:
http://www.gfgf.org/GFGF-Schaltplandienst/SternRadioRochlitz_Beethoven_sch.pdf
von peda (Guest)
> warranty etc.
Then I fear, you must spend a lot of money to get good quality.
I use a transistor amp (Onkyo) with digital input (Toslink) on the
computer.
This prevent switch on click, ground loops, noise, humming and other
hassle.
von combiner (Guest)
