Forum: FPGA, VHDL & Verilog Increasing dutycycle for an output signal
von Robert (Guest)
Hi all,
I want to increase the duty cycle slowly from 0%-50% in the period of
0-10 ms for an output signal(150KHz) generated from a clock of 50MHz.
I am able to generate the output for 50%. I am not sure how to vary the
duty cycle from 0-50% (between 0-10ms). Below is the code:
entity Gen_150 is
port ( sys_clk,reset: in std_logic; --sys_clk:50MHz
a_out, b_out: out std_logic);       --a_out,b_out:150KHz
end Gen_150 ;
architecture bhv of Gen_150 is
signal count: integer:=0;
signal tmp : std_logic := '1';
begin
process(sys_clk,reset)
begin
if(reset='0') then
count<=0;
tmp<='1';
elsif(sys_clk'event and sys_clk='1') then
  count <=count+1;
  if (count = 166) then   -- dutycycle=50% ((50000000/150000)/2)
     tmp <= NOT tmp;
     count<= 0;
  end if;
end if;
a_out <= tmp;
b_out <= NOT tmp after 10ns; -- output delayed by 10ns
end process;
30
end bhv;
Thank you!
von Duke Scarring (Guest)
You need another 'signal' generator (triangle wave, 100Hz) and connect
it with your comparator:
Constantly changing (slowly) your compare value (166), should do it.
Duke
von Okay (Guest)
Why not compare count to another register you can dynamically set in the
process instead of a constant?
Robert wrote:
> Below is the code:
> entity Gen_150 is
A VHDL code start well before the keyword "entity"...
Thats not synthesizeable! You know that?
Try that and change the value of pwm:
signal pwm: integer:=100;
  count <=count+1;
  if (count = 332) then
     count <= 0;
  end if;
end if;
tmp <= '1' when (count < pwm) else '0';
end process;
Now you have a changing output signal. And the only thing you must du,
is to produce a ramp on the "pwm" signal. Thats fairly easy...
von Robert (Guest)
Thank you!
I implemented the ramping function with a counter=500000 (0-10ms).
Please correct if I am wrong.
And I am getting an syntax error for the below:
tmp <= '1' when(count < pwm) else tmp <= '0';
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
entity Gen_150 is
end Gen_150 ;
signal counter: integer := 0;
signal pwm: integer := 0;
begin
begin
if(reset='0') then
count<=0;
tmp<='1';
  count <=count+1;
  --counter <= counter +1;
    -- tmp <= NOT tmp;
     count<= 0;
30
  end if;
31
end if;
32
33
34
a_out <= tmp;
35
b_out <= NOT tmp;
36
37
end process;
38
39
Ramp : process (reset, sys_clk)
40
begin
41
  if reset = '0' then
42
    pwm      <= 0;
43
  elsif rising_edge(sys_clk)  then
44
45
    if counter<=500000 then -- 500000 cycles =10ms
46
47
        case  counter  is
48
          when  50000     =>  pwm  <= 25;
49
          when  100000  =>  pwm  <= 33;
50
          when  150000  =>  pwm  <= 44;
51
          when  200000  =>  pwm  <= 66;
52
          when  250000  =>  pwm  <= 77;
53
          when  300000  =>  pwm  <= 99;
54
          when  350000  =>  pwm  <= 120;
55
          when  400000  =>  pwm  <= 132;
56
          when  450000  =>  pwm  <= 145;
57
          when  500000  =>  pwm  <= 166;
58
59
          when  others  =>  pwm  <= 0;
60
        end case;
61
62
    else
63
      pwm      <= 0;
64
    end if;
65
  end if;
66
67
end process Ramp;
68
69
end bhv;
Of course you do. What's the correct syntax for the when/else statement?
Why didn't you simply copy it from me?
Mine will not conclude in an error message.
And for the PWM value: let start it from 0. And then increment it every
500000/166 clocks. So you will only need an additional counter from 0 to
500000/166. And when the counter reaches that value you must reset it to
0 and increment the PWM value until its 166.
You see that there's no whatsoever "case" statement necessary at all and
the PWM value will increase smoothly from 0 to 166...
: Edited by Moderator
von Robert (Guest)
Sorry it was my mistake. Its fine now. But is the ramp function
implemented correct?
von Robert (Guest)
Thanks a ton! It works fine. :)
That's usually checked by a testbench...
von Robert (Guest)
I want to add delays between the outputs (a_out and b_out).
Is it ok to add a min delay(is 10ns too much?) just by adding a temp
register to delay out_b?
if(reset='0') then
count<=0;
tmp<='1';
end if;
end if;
a_out <= tmp; -- at falling edge
d_b_out <= NOT tmp; -- at falling edge
b_out <= d_b_out; -- delayed by 10ns - at rising edge
I am not sure as the Input clock has a frequeny of 50MHz and the outputs
are at 150KHz.
Only you know that...
> just by adding a temp register to delay out_b?
With a 100MHz clock thats the only way to do it...
von Wil (Guest)
How do I introduce a 180° phase shift between a_out and b_out. I tried
using an inverting output. But when dutycycle is 10% for a_out, it is
90% for b_out. But I want a 10% dutycycle for b_out with 180° phase
shift.
Any suggestions?
> I tried using an inverting output.
A phase shift is only defined for sinusoidal signals. And then inverting
is correct.
What you want in fact is a delay of half the cycle duration for one of
the signals.
von Wil (Guest)
Yes. Exactly. But the main clock is 50MHz and the outputs are 150KHz.
How do I give a synthesizable delay.
Use a second PWM unit that counts half a cycle delayed.
Or simply use a shift register.
