Forum: FPGA, VHDL & Verilog From java to FPGA (general concept)
Author: Junior Hpc (Company: University) (junior_hpc)
Hello everybody. I would like to develop a word counter for my FPGA
starting from Java but I'm not sure how to proceed. The idea is to
create a Java circuit description of the application using JHDL in order
to generate the netlist and then push it into my FPGA. Is it how the
steps should go?
Junior H. wrote:
> The idea is to create a Java circuit description of the application
> using JHDL in order to generate the netlist
What toolchain is able to handle this?
In what manner is Java suitable to describe hardware?
Author: rm (Guest)
1 useful
After creating the EDIF netlist, you will need to run the FPGA vendor's
tools which convert an EDIF netlist to a bitstream. In case of Xilinx,
these might be the Alliance or Foundation tools. At any rate, the
execution of these tools is outside the scope of this JHDL getting
started guide and will be specific to your FPGA site setup.
more on:
http://www.jhdl.org/documentation/starter.html
JHDL is a software that given a Java hardware description as parameter
(basically are java files that contains methods to describe input,
output and behaviour of hardware components) it outputs a netlist.
more on: http://www.jhdl.org/documentation/starter.html
> more on:
I have a Xilinx Artix 7. I Should use Vivado, isn't it? Anyway, guessing
from your posts it seems the right direction.
Thanks to you all.
  • [vhdl]VHDL code[/vhdl]
