Forum: FPGA, VHDL & Verilog Ethernet MAC - PHY transmit
Author: Szymon Piotrowski (sion111)
Hello,
I am trying to write a simple template frame transmitter using MII in
verilog. The ethernet frame format I am using looks like
preamble (7B) > frame delimeter (1B) > Dest. MAC (6B of 1's to
broadcast) > Source MAC ( 00:11:22:33:44:55) > LENGTH (4B, typing 100
for 100 octetcs of data) > DATA (100 octets of 0's) > FCS (4B,
calculated using http://www.zorc.breitbandkatze.de/crc.html) with data
(from dest MAC to the end of actual data) i've just provided.
I am aware of the fact of reverse order of bits needed by the ethenret
frame. To capure any data from PHY i am using Wireshark, but it shows
only some frames from the PC (used, for example, to establish connection
or trying to communicate, i guess).
Is the timing of TXEN correct? Or is it something wrong with the
implementation?
I would appreciate any help in making the code sending that frame.
(The files attached presents the code itself and the start and end of
frame to be transmitted (to show the TXEN timing)
Author: Verilog hotline (Guest)
What is your target platform for the Verilog code?
From what I read it sounds like you are trying to run Verilog code on
your PC to send something through your PC network card.
The transmitter code is a part of a bigger project. It runs on a Lattice
LFXP2 fpga. The FPGA is connected to MTXC (the clk of the module) MTXEN,
MTXER and MTXD3-0 of PHY device (KSZ8863). PC network card is connected
to the PHY device. I can see that the link is established to 100Mb/s
(what is correct since the external crystal provides 25MHz). Wireshark
does not show any packet from the PHY.
Are you syncing the tx signals to the external clock?
Are you sure your CRC is correct?
Are you sure that your PHY really sends your packet?
Most PHYs have a loopback that can be enabled for debug. You could test
if your PHY responds by enabling a loopback to PC side (and send sth. to
the PHY, i.e. using Ostinato) and you can test if your PHY would really
send your packet with the loopback to MAC side.
1. they are synced to the MTXC pin that is PHY transmit clok pin.
2. it can be as correct as the internet caclulator done it (but i have
used MIIM to make a change in phy's control register to switch all
packages, including bad ones).
3. no, i am not, since neither wireshark nor etherdetect shows anything.
The is only a TX side used for now, so a loopback may not come in handy.
Author: Dose (Guest)
1 useful
I have written also a MII interface in VHDL
see
 Beitrag "Ethernet GMII"
The starting code has a mistake in the preamble.
Author: Lattice User (Guest)
1 useful
> see
That would Wireshark not prevent to see something.
But a fully functionally Wireshark requires a
network card which can be set to promiscous mode and
that also will forward packets with incorrect FCS.
It is also advisable to use a driekt (crossover)
connection, as switches also drop errornous packets.
now it is 14x 0x5 then 0xD and 0x5 (as in
https://en.wikipedia.org/wiki/Ethernet_frame)
As far as I understand Your code, it should be 13x 0x5, 0xD and than
start of mac addressing?
This is because of GMII is sending a byte at once and MII is sending two
nibbles with least significant nibble first.
So
should be okay.
Regarding the FCS, you could just send the frame with the 100 zero bytes
from your PC (I already mentioned Ostinato which has a GUI and runs on
Win/Linux but there are other command line tools also) and monitor it
with wireshark, then compare the FCS that is automatically created with
your FCS.
Also you can configure your PHY in loopback mode to PC side to know if
your network card is in promiscuous mode.
For both you do not need to implement an RX in your FPGA.
1 useful
Which is wrong.
The IEEE 802.3 standards are part of the IEEE get program and available
free of charge:
http://standards.ieee.org/about/get/802/802.3.html
MII is described in section 2,  chapter 22.
Table 22-3 shows exactly how to send the preamble.
You are right, thanks.
About checking FCS on wireshark or Ostinato, they just do not show any
Packets (raw ethernet frames, still without fcs shown) from Ostinato are
captured as Malformed Packets with ARP protocol.
And are they returned when you enable PHY external loopback? Maybe you
should also set a valid ether type, as otherwise this may be interpreted
as length and may be discarded by your network card.
Author: Trundle Trollkönig (Guest)
1 useful
hi,
just google for Colasoft Packet Builder and download it. You can fill in
your own Packet (bytewise) and it will calculate the CRC32 for you. I am
using this programm to check the CRC32 values from my Ethernet packets,
it works.
In Wireshark have you set the promiscuous mode under capture options?
Ok, then, what about bit order. I assume that if my TX is
(phytx3,phytx2,phytx1,phytx0) and i want to transmit 0x0806 I should do
it like:
TX<=4'b1000;
TX<=4'b0000;
TX<=4'b0110;
TX<=4'b0000;
But what about FCS? The wiki states:
"the least-significant bit is transmitted first, except for the frame
check sequence (FCS)."
For example, let the first byte of FCS be 0x14;
Should I do it the same way? (transmit 4, then 1), transmit it "as is"
(1, then 4)...or reverse it from 0b00010100 to 0b00101000 and transmit
it like 2 then 8, or 8 then 2?
  • [vhdl]VHDL code[/vhdl]
