Forum: FPGA, VHDL & Verilog Using VHDL Arithmetic Operators on FPGA Chips
Author: Warren Toomey (doctorwkt)
Hi, I'm learning VHDL and I've implemented a 16-bit microcoded CPU in
VHDL using GHDL as my platform. The source code and a description of the
CPU is here: http://minnie.tuhs.org/Programs/UcodeCPU
I'd like to buy a FPGA development board and get the CPU into silicon.
However, in the ALU I have used the VHDL arithmetic operators +, -, *, /
and rem. This is cheating of a sort, as I didn't really implement any of
these with real gates.
When it comes to targetting an FPGA, is this going to cause problems? Am
I going to have to go back and build adders, subtractors, multipliers
etc.? Or can most FPGAs implement the VHDL arithmetic, albeit
inefficiently?
I'm not too worried about the speed of the CPU, just that it works!
Many thanks in advance for your helpful feedback,
     Warren
Author: Achim S. (Guest)
+ and - can be implemented in real hardware quiet easily, they should
work without problems and run very fast. For * and especially for / it
is somewhat harder. No problem at all for a simulation with GHDL, but it
can be kind of problem if you want to map these operations with 16 Bit
width to real hardware. The logic needed to implement a 16Bit division
in a single CLK-cycle can be quite large.
Get a version of some FPGA development software (both Xilinx and Altera
have free versions of their development systems). Try not only to
translate your code, but to implement it on some (virtual) FPGA. Even if
you do not yet have any real FPGA available, the development system will
tell you, if it would be able to fit the logic into that hardware, how
fast it would run there and how much resources it would consume.
Most FPGAs have dedicated and optimized logic-Blocks just for
arithemtics (called e.g. dsp48), which are present on the FPGA anyways
(so not using them will not save you any ressources). They can e.g.
execute a multiplicaiton for large bit widths in a single CLK-cycle at
high frequency. For Division there exist typically IP-Cores, which make
use of these dsp-cores and wich you may also implement in your design.
They only need a few CLK-cylces for a division. (see e.g.
http://www.xilinx.com/support/documentation/ip_doc...)
Using these blocks should save ressources and give you much nicer
performance than the implementation of * and / with standard logic
slices.  But for a first try you may also keep the operations in your
VHDL-code as they are and see, what the development system makes out of
it and how fine it is running ;-)
Achim S. wrote:
> Try not only to translate your code, but to implement it on some
> (virtual) FPGA. Even if you do not yet have any real FPGA available, the
> development system will tell you, if it would be able to fit the logic
> into that hardware, how fast it would run there and how much resources
> it would consume
It does much more: if you target a specific FPGA the toolchain will
generate an implementaition specific schematic. Have a look at that
schematic and you will see, how much hardware is needed for the
operation.
Thanks Achim and Lothar for you feedback. I'm also keen on trying out
the PDP-11/70 processor on opencores.org, so I'll install and play with
the Xilinx toolchain. Eventually I will buy a Nexys4 when I'm ready to
try my own CPU out on a real FPGA.
I'm sure I'll have more questions in the future! Thanks again.
    Warren
  • [vhdl]VHDL code[/vhdl]
