Forum: FPGA, VHDL & Verilog VHDL (GHDL): can't have multiple entities in file?
von Edmund (Guest)
Hello, this is my first post. I'm very new to digital logic and VHDL. I
started by making some VHDL for just a clock, which I was able to
compile with VHDL just fine, and simulate, and view the output in
gtkwave.
What I was hoping to do next is just an 8-bit ripple adder. However, I'm
stuck on an error. The following VHDL:
library ieee;
use ieee.std_logic_1164.all;
entity and_gate is
    port (
        a, b: in std_logic;
        a_and_b: out std_logic
end;
architecture behavior of and_gate is
begin
    process (a, b)
    begin
        a_and_b <= a and b;
    end process;
end;
entity xor_gate is
    port (
        a: in std_logic;
        b: in std_logic;
        a_xor_b: out std_logic
end;
Fails with the errors:
$ ghdl -a 8_bit_adder.vhdl
8_bit_adder.vhdl:23:15: no declaration for "std_logic"
8_bit_adder.vhdl:24:15: no declaration for "std_logic"
8_bit_adder.vhdl:25:22: no declaration for "std_logic"
ghdl: compilation error
The error goes away if I delete the "xor_gate" entity. I'm surprised at
the error as I don't know why I wouldn't be able to use the same type
(std_logic) several times. Please help! :)
: Locked by Moderator
Edmund wrote:
> library ieee;
Thats missing before the second entity. Each VHDL module starts with the
used libraries...
von Edmund (Guest)
That was it!
Thank you.
von Edmund (Guest)
Unfortunately, I've run into another error that I don't know how to
interpret.
The following VHDL:
library ieee;
entity and_gate is
    port (
        a: in std_logic;
        b: in std_logic;
end;
begin
    process (a, b)
    begin
        a_and_b <= a and b;
    end process;
end;
library ieee;
entity xor_gate is
    port (
        a: in std_logic;
        b: in std_logic;
end;
30
31
architecture behavior of xor_gate is
32
begin
33
    process (a, b)
34
    begin
35
        a_xor_b <= a xor b;
36
    end process;
37
end;
38
39
library ieee;
40
41
42
entity half_adder is
43
    port (
44
        a: in std_logic;
45
        b: in std_logic;
46
        sum: out std_logic;
47
        carry: out std_logic
48
49
end;
50
51
architecture structure of half_addr is
52
    component and_gate is
53
        port (
54
            a: in std_logic;
55
            b: in std_logic;
56
57
58
    end component;
59
60
    component xor_gate is
61
        port (
62
            a: in std_logic;
63
            b: in std_logic;
64
65
66
    end component;
67
begin
68
    g1: xor_gate port map (
69
        a => a,
70
        b => b,
71
        a_xor_b => sum
72
73
    g2: and_gate port map (
74
        a => a,
75
        b => b,
76
        a_and_b => carry
77
78
end;
Yields:
8_bit_adder.vhdl:53:14: entity 'half_addr' was not analysed
It is probably obvious that this is my first structural VHDL
architecture, I'm having trouble finding a good resource on VHDL
syntax/semantics. Thank you in advance.
: Edited by Moderator
von Edmund (Guest)
Oh uh.. nevermind. "half_addr" versus "half_adder".
Edmund wrote:
> Oh uh.. nevermind
Ok, but in the next post with VHDL code try that (its to be found a few
lines above the edit box):
[vhdl]VHDL code[/vhdl]
von Danial Sadiq (Guest)
Hi, I was trying to combine my 4:1 mux and register together. By using
the method above, where in the code should i put my processes of both
the components? in the port map?
Danial Sadiq wrote:
> By using the method above
There you can see two entities and_gate and xor_gate which are used as
components in a top level entity half_adder.
> in the port map?
In a port map you have to put the ports of the entity. And that
entity afterwards is instantiated as a component in a top level entity.
You can see, that the two processes in the two entities and_gate and
xor_gate do not show up in any port map.
Which mux and which registers? I can't see no code with that...
Post your code (wrap it as described with the [vhdl] tags), then we can
discuss your particular problem.
von René D. (Company: www.dossmatik.de) (dose)
Please use in one VHDL-file only one entry.
Your code will be better readable.
Half-add and full-add are only simple demonstrators. The VHDL-language
has for this the operator +  for signed and unsigned signal.
This topic is locked and can not be replied to.
