Guest
#4147477
hallo together, today I have a little question: Is it possible to turn a common FIR-bandpass into a bandpass with 90 degree phase shift? And if possible, how to do? My usual procedure: 1. make a lowpass for the lower frequency edge (sin(x)/x * Blackmann) 2. make a second lowpass for the upper frequency edge (also sin(x)/x * Blackmann) 3. normalize both lowpasses 4. turn the second lowpass per spektral inversion to a highpass 5. add both passes, this makes a band reject pass 6. turn it into a band pass by spektral inversion This makes all the taps for a decent FIR-bandpass, it works fine for even as well as for odd tap numbers, but without any phase shift. The output is limited to the desired frequency span as requested, so I hope it should be possible to add a 90 degree phase shift to it (a la Hilbert) A decent testbench for the a.m. filter I already have written for myself, but not yet for a added Hilbert transformation. so, has anyone a nice idea for this? kind regards W.S.
