Forum: FPGA, VHDL & Verilog outputs is unutilized
Author: had (Guest)
the buttonOut, flipflops and temporal is un-utilized after the frequency
divider process is added into the codes..
I couldn't figure out the problem as I'm new to vhdl..
my codes is as below..
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity debounce is
  --counter size (19 bits gives 10.5ms with 50MHz clock)
  generic ( counter_size  :  INTEGER := 4);
  port( clk       : in  std_logic;  --input clock
        buttonIn  : in  std_logic;  --input signal to be debounced
        buttonOut : out std_logic); --debounced signal
end debounce;
architecture debounce of debounce is
  signal flipflops   : std_logic_vector(1 downto 0); --input flip flops
  signal counter_set : std_logic ;                    --sync reset to zero
  signal temporal: std_logic;
  signal counter : integer range 0 to 124999 := 0; --counter size(200Hz)
  begin
  counter_set <= flipflops(0) xor flipflops(1);--check when to start/reset counter
  --freqeuncy divider process
  process (clk) begin
    if rising_edge(clk) then
      if (counter = 124999) then --Condition met
        temporal <= not(temporal);
        counter <= 0;
      else                       --Condition not met
        counter <= counter + 1;
      end if;
    end if;
  end process;
  --debounce process
  process(temporal)
  begin
    if(rising_edge(temporal)) then
      flipflops(0) <= buttonIn;
      flipflops(1) <= flipflops(0);
      buttonOut <= flipflops(1);
    end if;
  end process;
end debounce;
: Edited by Moderator
This is NOT a way to generate a clock inside a FPGA. Check out how to
generate and use a "clock enable".
How do you see this? What target and what toolchain is used? What is the
exact error message or warning?
Author: VHDL hotline (Guest)
Initialize/reset temporal. If you simulate it: not(U) is U and there is
never a rising edge of temporal, so fliflops and buttonout are never
assigned.
As Lothar said, use a clock enable or if the complete functionality are
only these two processes, just add the fliflops/buttonout assignment
directly to your first process and discard the second one, so the
counter value itself is your clock enable.
  • [vhdl]VHDL code[/vhdl]
