differences in board
OP (Company: Naval Undersea Warfare Center) #4047579
What is the difference between an fpga development board, an fpga
starter kit and  just an plain fpga board?
I am referring to the Altera Cyclone II fpga that seems to come in a all
three of the listed above versions.
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Moderator (Company: Titel) #4047616
Just different names for the same thing. So add the boards name to the
phrase and everyone is happy.
However: you must read the boards spec to figure out whether it fits
your needs or not...
Guest #4049286
I would say that a plain FPGA board does not contain more than the most
basic components to run an FPGA: Oscillator, JTAG interface, maybe a
regulator and lots of headers for I/O. You would need an external
programmer.
An FPGA starter kit contains some interesting peripherals,  but not too
complex - for starters only. Maybe a programmer is also available.
FPGA development boards contain lots of all kinds of complex peripherals
like Ethernet, USB, display, a programmer and much, much more. That
depends on the target applications like audio/video, motion control and
so on.
OP (Company: Naval Undersea Warfare Center) #4049855
Okay, I want to use the free high level synthesis software LegUp. The
video that you see on Youtube shows an Mandlebrot design pattern and its
speedup using LegUp. They use an Altera Cyclone II fpga. What board
could I use to replicate that test?
Thanks in advance.
Respectfully,
Lou_Reed
#4049881
James Yunker wrote:
> What board could I use to replicate that test?
I don't want to explore the video, so it's up to you: Can you find out
what board or hardware they use? Obviously something with a video
output.
BTW, I have an Altera/Terasic DE2 board here which is equipped with a
VGA output. Would you be able to modify the original code so that it
fits to a possibly different hardware?
Does your system support some kind of Altera-compatible programmer,
preferably the USB Blaster?
Regards, Uwe
A question of your own? This thread is over 11 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
