Forum: FPGA, VHDL & Verilog Multi-source error
Author: Javier PA (lascameador)
Hi guys!
I'm developing a system with an inout signal, like a bus.
I have two processes, driven by chip-enable signals, that they use this
inout signal, but they never asssign it at the same time.
Any advices with multi source error?
Thanksss!
> inout signal,
That is a very, very ancient coding style...
Maybe the synthesizer cannot resolve the chip-enables in a way that this
bus can be rolled out to the necessary MUX structure. Where do those
chip-enables come from? Can you show the relevant code?
I'm going to try to explain that haha. If you don't understand anything
tell me please because I'm spanish and it's hard to me write what i'm
thinking exactly.
I'm developing an I2C slave, so I don't show my code because it's too
big for my error I think. But i tried to do a scheme (attached file).
i'm working with an I2C bus. firstly process1 is an i2c slave, it gets 5
bytes and ends transmision,  and then ,process2 works with user logic.
they never work together (I use a state machine). Both proccesses have
to read and write SDA line and here it is my mystake.
Author: Lattice User (Guest)
For I2C use separate data out signals and combine them outside the
processes.
You cannot do this inside a real FPGA. Only for simulation you can
"connect" the signals in a testbench top level.
Apart from that technical possibility: it makes no sense to use an I2C
bus inside an FPGA.
  • [vhdl]VHDL code[/vhdl]
