Forum: FPGA, VHDL & Verilog need help in counter code
Author: Basim Sheikh (Company: kfupm) (kurapica)
i need help in my project which is a counter that counter up or down
fron 0 to 20
i alraedy did my counter code and its working will in active HDL
but know i need to show the numbers in 7segment in nexys 3 fpga board
i have the codes of the segment but i have a problem when i call the
module of segment , it is giving me an error in active HDL
can you please tell me what is the error
i am attaching my code and also writing it here
this is my current code :
module main
  #(parameter N=7)
  input switch,
  input button,
  input fastclk,
  output [3:0] enable,
  output reg[6:0] out
  wire[N:0]count;
  wire slowclk;
  clock c1(fastclk,slowclk);
  Updown u1(switch,button,slowclk,count);
  segment s1([3:0]count,[7:4]count,fastclk,enable,out);
endmodule
module clock(fastclk,slowclk); //clock code
  input fastclk;
  output wire slowclk;
  reg[25:0]period_count = 0;
  always @(posedge fastclk)
    begin
      period_count <= period_count + 1;
    end
  assign slowclk = period_count[25];
endmodule
module Updown // UpDown Counter
#(parameter N=7)
  input switch,
  input button,
  input clk,
  output reg [N:0]count=8'd0,
always @(posedge clk)
  begin
    if(switch == 1 && button == 1)  // Countup from 0 to 20
      begin
        if(count == 8'd20)
          count <= 0 ;
        else
          count <= count +1;
      end
    else if(switch == 0 && button == 1) // Countdown from 20 to 0
    begin
        if(count == 8'd0)
          count <= 8'd20 ;
        else
          count <= count -1;
      end
    else count <=8'd0;
  end
endmodule
module mux(A,B,sel,Y); // 2x1 Multiplexer
  input [3:0]A;
  input [3:0]B;
  input sel;
  output [3:0]Y;
  reg [3:0]Y;
  always @(*)
    begin
      if(sel==0)
        Y=A;
      else
        Y=B;
      end
endmodule
module hex7seg(input wire [3:0]x , output reg[6:0]a_to_g); // Hex to 7seg Code
  always @(*)
    case(x)
      0: a_to_g = 7'b0000001;
      1: a_to_g = 7'b1001111;
      2: a_to_g = 7'b0010010;
      3: a_to_g = 7'b0000110;
        4: a_to_g = 7'b1001100;
      5: a_to_g = 7'b0100100;
      6: a_to_g = 7'b0100000;
      7: a_to_g = 7'b0001111;
      8: a_to_g = 7'b0000000;
      9: a_to_g = 7'b0000100;
      'hA: a_to_g = 7'b0001000;
      'hB: a_to_g = 7'b1100000;
      'hC: a_to_g = 7'b0110001;
      'hD: a_to_g = 7'b1000010;
      'hE: a_to_g = 7'b0110000;
      'hF: a_to_g = 7'b0111000;
      default: a_to_g = 7'b0000001;
    endcase
endmodule
module segment (a,b,fast,enable,seg7);
  input [3:0]a;
  input [3:0]b;
  input fast;
  output [3:0] enable;
  output [6:0] seg7;
  wire [3:0]e1 = 4'b1110;
  wire [3:0]e2 = 4'b1101;
  wire slow;
  wire [3:0]number;
  clock c1(fast,slow);
  mux m1(a,b,slow,number);
  mux m2(e1,e2,slow,enable);
  hex7seg h1(number,seg7);
endmodule
: Edited by Moderator
Can you please tell the ERROR MESSAGE and the corresponding line?
this picture is showing the error line and MESSAGE
: Edited by User
A syntax error is the most simple error that can occur. It shows up,
when some character are not in the expected order. The compiler tells
you, whats wrong. Correct it and try again. This extremely simple error
here you must solve on your own. The necessary process is called:
LEARNING!
I'm the VHDL man, and I don't know Verilog. But it took me less than 1
minute and a Google search
https://www.google.de/search?q=verilog+port+list to figure out whats
leading to this error. Try this here:
  segment s1(count[3:0],count[7:4],fastclk,enable,out);
  • [vhdl]VHDL code[/vhdl]
