Forum: FPGA, VHDL & Verilog fpga vhdl serial read operation
Author: Kumar (Guest)
I'm doing write and read operations from a SPI master.
While writing I'm simply writing the 14 bit address followed by
read/write followed by 16 bit data. The slave then takes this info and
does actual writing operation.
But while reading I'll first write to a register in the slave,  address
followed by read/write bit (& no data or x"0000" because I'm reading).
The very next cycle I want data to be avaialable for reading. But the
slave takes sometime/cycles to go fetch the data from the address I just
wrote to the register. While the slave goes and brings the data for me I
want to keep my spi master idle and continue once the data is fetched,
so I can read it serially at spi master using a miso line. How can I do
this.
(I'm using a simple shift register spi to shift and serially transmit 32
bits)
Kumar wrote:
> How can I do this.
Read your own post as if you know NOTHING about your system and your
problem (thats the way all of us must do it). When you done that: can
you understand the question?
Kumar wrote:
> a SPI master ... the slave
What is the "a master" and what is "the slave"?
> The very next cycle
What is the "very next cycle"? The "very next cycle" of what?
Kumar wrote:
> While the slave goes and brings the data for me I want to keep my spi
> master idle
You know that SPI is only 2 shift registers coupled behind each other
(or in a loop). So if you want get something from the slave, the master
must be active and generate the SLCK at least. The slave itself
doesn't "go" anywhere...
Author: P. K. (pek)
The environment variables of your question are pretty undefined, but as
you write to an FPGA forum, I assume that your slave is located in an
FPGA.
Furthermore undefined is the clock speed of your SPI. "Usually", it is
quite slow compared to the FPGA system clock.
So I assume you implement your SPI by oversampling the inputs and
trigger FPGA internal actions based on SPI clock edge detection.
So with all those assumptions, the solution is pretty easy: After the
address have been applied, you read your register anyway, in parallel to
the incoming read/write bit. If the bit turns out to indicate "read",
you have your data already stored in the output shift register.
Because (as assumed earlier) the system clock is by far faster than the
SPI clock, you have plenty of system cycles to do your register read
during reception of the read/write bit.
  • [vhdl]VHDL code[/vhdl]
