Forum: FPGA, VHDL & Verilog Goertzel Algorithm in Verilog / Frequency Recognition
Author: Nikita Gusev (nikitag)
Hello,
For my final project I am making a game that will be able to recognize
when specific frequencies are played through the Audio In, and make an
LED light up as a result. I am not looking to store the Audio in memory,
just to be able to recognize when a specific frequency is played. I was
recommended to use the FIR, but apparently that does not produce a
binary value to indicate that the frequency was found.
I am using the Altera DE2 board, with the Cyclone II FPGA.
Thank you in advance,
Nikitag
: Edited by Moderator
Author: Christoph Kessler (db1uq) (christoph_kessler)
1 useful
Search for "goertzel algorithm verilog".
Hello,
I recently received a suggestion to use the Goertzel Algorithm to
recognize when a specific frequency is present in an Audio input stream.
Unfortunately I have not had any luck with research in finding any
implementation in Verilog. I am using the Altera DE2 board for my
project. Is there a module (like the FFT) on the board taht can perform
this algorithm? I am new to Verilog so any help is appreciated, thank
you.
Is homework today: "Find a working implementation on the internet!"
So: start yourself and if you have a concept and encounter problems THEN
ask. But no one here is intended to do your homework.
Author: Lattice User (Guest)
Nikita Gusev wrote:
> Hello,
Following up on your old thread would probably gotten you a better
response
http://embdev.net/topic/350046#3886737
> response
Thx, I will concatenate them...
Beitrag "Re: FFT Algorithmus in FPGA umsetzen"
on page 350 of that book you find the equations for goertzel algorithm
in programmable logic.
For that book you find example code in Verilog here:
http://uisprocesadores2008.wdfiles.com/local--file...
but there is no example for goertzel as far as i see
  • [vhdl]VHDL code[/vhdl]
