Forum: FPGA, VHDL & Verilog High speed FPGA design
von Silver (Guest)
Hi ,
I have some experience designing FPGA IP's for projects( under 100Mhz).
My Question is , is there any special design / knowledge that I need to
know in-order to design what is considered high speed FPGA designs say
100 - 400Mhz range ? designs. I am talking about designs on an FPGA and
not FPGA + board design.
Please let me know if anyone has been involved in so-called high speed
FPGA design projects
Thanks in advance
von Schlumpf (Guest)
> 100 - 400Mhz range
No
The synthesizer and PaR will do that for you by using the constraints
you define.
But:
The higher the desired speed the shorter the time for logic and routing.
So it´s up to you to avoid excessive logic between the registers.
von Alexander F. (alexf91)
As Schlumpf already said, you have to avoid excessive logic.
You can split up logic in smaller parts and add registers in between
(pipelining).
This should increase the possible clock and throughput, as long as can
keep all stages busy.
