Forum: DSP Processing/Sampling IF(IQ) signals
Author: Himadri (Guest)
Signal Characteristics: The IF (I/Q) signal consists of a DC component
and an AC component.
DC Component: 2.52V; AC Component: 1.72 – 2.04 V (V P-P); BW: 20Hz -
500kHz; Power: 20dB
Requirement: Now I want to digitize this signal for further processing.
I prefer a sampling at 1 MSPS with ADC and then porting digital data to
PC using a FPGA over SPI interface.
Problem: The problem is, the signal with DC and AC component ranges from
3.5V to -1.5V with 2.5V from DC and almost 1V from positive cycle or
negative cycle of the AC signal. Now I can use a coupled capacitor to
block the Dcand use the AC for processing. My choice of ADC reference
voltage is almost 2V-2.5V (for good resolution usability of ADC) so the
signal can be amplified. But this signal have a negative part which I
think is not good for a linear behavious for the ADC, as it has no
negative reference voltage level. ADC reference is from 1V-5V. Using a
rectifier is not a good choice from my view.
Question: How can I digitize this signal? Also comment on my views if
not correct as I have only theoretical knowledge and never worked on a
practical project.
Author: foo (Guest)
> not correct
So it is.
Vpp means peakt to peak voltage, i.e. the maximim amplitude ist 1.02V.
When added to the DC voltage then the mininum Voltage is +2,52V - 1.02V
= +1,5V and teh maximum volatge is +2.52V + 1.02V = 3.54V.
