Forum: FPGA, VHDL & Verilog function "to_integer"
Author: Mira Miyou (Company: LERICA) (ramiss)
I have a problem when using this function and i have this message :
"Argument of 'to_integer' function must have size less than 32"
from what I understand, the to_integer function from numeric_std works
with 32 bits vectors max!!!
is there a way to make it accept 64 bits vectors? ou more?
or is there some other function i should use?
Thank you a lot,
Regards,
Author: Peter K. (Guest)
What programming language do you use?
Maybe the function name is to_long, or you could transform the 64Bit
vector to 32bit, this truncates the information in the lower 32Bit but
maybe the precision is enough for your purpose.
Why would you transform to integer datatype, if your datatype is double
just round it and keep the double datatype
Thanks for your quickly response,
I use VHDL language (xilinx ISE),
The program concerns manipulation of image block data in order to
achieve a motion estimation, I use a register (32bits) for saving (or
delaying) the data, thus the program works when data size is less than
32-bits but in my case I need 64-bits, so how can I do this?
Thank you,
Truncate the 64 Bit to 32 Bit or use 2 32Bit Register for saving the
data.
1 for the low 32Bit the other for the high 32Bit and perform the
operation with two registers.
Author: -gb- (Guest)
You could use unsigned/signed. They are not limited in length.
> data.
Thank you again for your valuable comments,
I did as you mentioned, I split my data into two parts, once using
32-bit registers, and the second part another 32-bit registers, only I
hope it wont be a blend of data :)
Thank you all,
Best regards,
And what do you do with that segmented value afterwards?
My way would be to use a unsigned(63 downto 0) vector and the
numeric_std for the calculations with it...
Actually I reduced the size of register at 32bits and I changed the way
in which the data are presented in my program so that it goes with the
32bits, since anyway I can't go beyond.
concerning the function unsigned, I don't use it because before storing
the value in the register I use an absolute value like this:
abs (to_integer (signed (data)))
thank you again for the time you spent to write me,
Author: berndl (Guest)
you should accept the fact that VHDL has integers (that's signed by the
way!) of only 32 bits. For anything beyond this, you might follow
Lothars advice and go to 'signed' and 'unsigned' (which are unlimited in
bit-width)...
> bit-width)...
Ok, thank's for your advice :)
Regards,
  • [vhdl]VHDL code[/vhdl]
