Forum: FPGA, VHDL & Verilog send UDP packets from FPGA
von meleneemil (Guest)
Hello all,
I am trying to create a UDP socket with an FPGA.
The aim is to send UDP packets to a PC which will read them and so on.
However, I am having a hard time implementing. I have googled too much
already.
I guess that just by using the core generator of Xilinx would give me
what I want ready to go.
However it is not just about the code; it is also about the
implementation.
The .ucf in particular has given me metaphorical nightmares.
If someone has a complete example or project they could share, or just
specific advice, it would be great.
thank you.
Emil
von Aimilianos K. (aimilianos_k)
Forgot mention:
the board is ML605 evaluation board.
What level of knowledge do you have with FPGAs? Did you already
implement some simpler hardware?
von Schlumpf (Guest)
You have to implement a MII-Interface (or GMII or RMII) to connect the
required PHY.
And then you have to implement a state machine that feeds the
MII-Inteface with the frame data.
And after that you should implement a FCS-generator that calculates and
adds the checksum to the frame.
If you don´t want to implement a FCS-generator you have to switch your
NIC to promiscuous mode to avoid filtering frames with wrong FCS.
with MII the data-clock is sink-driven. So your interface might be
asynchronous to the rest of your FGPA. So you have to implement a domain
crossing via e.g. fifo memory and you need a proper constraining of you
wohle design.
First of all, thanks for your quick responses.
My experience is limited I have to say.
I have exercised vhdl for some time, starting with sinmple examples,
which went fine.
I have worked a little on the ML605, and played a little with the clock
and some leds.
However, in order to compute some more complex stuff, I guess I should
get into the pc-fpga communication.
I have gone through the ML605 schematic quite a lot. I think I have
understood most of the pins that are going to be used for an ethernet
communication.
> the
> required PHY.
agreed.
again I agree (based on other examples I have seen e.g. from opencores)
I think I can almost understand what the Frame check sequence generator
should be doing. I am not very confident that I could write it myself
though.
> wohle design.
I did not really get that last part. ( didn't google for it either)
In any case, I was thinking that I could implement the ethernet mac core
from the  Xilinx Core Generator. This should save the time and workload.
But even for that, there are certain basic that I cannot understand.
The UCF file, for example. I cannot find specific info about some pins
of the core, so I don't know how important they are, and if they should
be connected somewhere, or just left free.
Also, for starters I would send a custom packet. I mean that I would not
have to read+send data from memory or some random generator.
thanks again everyone!
(I am mostly self-taught, so I probably have some gaps in basic
knowledge.)
Emil
von jonas biensack (Guest)
The idea is good, but why don't use a much simpler communication medium
like rs232? If this works you can use the rs232 channel as
"debugger/communication channel" for developing and testing the udp
communication.
>though.
Search for a suitable core in the web, or just don't use any crc
calculations but in this case be aware of this:
kind regards
Jonas Biensack
Hello all,
I have the ML605 board. I want to send UDP packets through ethernet to
the PC.
 - I generated the mac core through the Core generator.
 - I have the example-design files.
 - Load them in Xilinx ISE, and it seems to compile ok
(synthesis+implement+generate programming file).
 - I program the fpga with the .bit file.
 - The PHY leds go on, and the speed config seems to work fine.
 - The DUP led is on. The TX never goes on. The RX lights up every few
seconds, apparently due to packets from the PC (standard ethernet search
for connection I guess).
Now the issue:
It should be enough to trigger a DIP switch to turn the packet generator
on, but nothing happens.
Q: Assuming the core works fine, WHAT should I do to send packets to the
PC.
The packet data can be predefined-hardcoded or time dependent.
I just need to see that I can send from the fpga.
thank you all.
Emil
Do you have a scope or a logic analyzer?
Somwhere in between here is missing:
- I set up a testbench and run a simulation, which works fine.
BTW: I joined your two threads together, because they relate to the very
same
problem.
I do not understand.
I think I have neither, but also I probably don't know what they are.
I understand that. However: Can I just simulate ethernet communication
inside ISIM?
Of course I should try, but I have doubts for the ability of the
simulation to certify that such a design would work.
In any case, I am not doubting your expertise.
> same
> problem.
Ok. I will keep it in mind next time. Thanks.
> Can I just simulate ethernet communication inside ISIM?
You do not simulate the complete Ethernet communication. You just
simulate the communication to the phy on the MII interface. Just to have
a look whether the MAC and the example design work at all...
With an oscilloscope you could see whether theres any activity on the
MII interface. With a logic analyzer you could trace down to the
telegram level. without any (and without a working simulation) you are
virtually blind and can react just on third party information like
flickering LEDs...
: Edited by Moderator
If I get it right:
The simulation will only show whether or not there is data going to the
TX ports?
(still something).
I will try it.
Isn't there any easier way to send data through ethernet?
You could do it from your PC...
Ethernet is a abstract high level medium. So there is no simple way to
get it running as easy as eg. a RS232 communication...
I am trying to make it work in a testbench.
However I think I need to implement the LVDS somehow, and I cannot
understand.
Obviously it can't be just two clocks with phase difference.
Q: How can I simulate LVDS in the testbench?
thank you Lothar and everyone!
This is the wrong abstraction level for the testing the behavior of
your interface!
See http://en.wikipedia.org/wiki/Media_Independent_Interface
And so the interface is only 16 digital signals connected between the
FPGA and the PHY. Because the PHY is a device with a datasheet you can
implement this interface by the PHYs datasheet. At this behavioral level
there is no need of LVDS or similar.
von priyanka reddy (Guest)
hi i want to implement tcp offload engine using fpga using altera arria
5 development board.can you please help me with these project
