Forum: FPGA, VHDL & Verilog 16 bit PISO register
Author: Omar Rashad (Guest)
I am trying to write the VHDL code for a synchronous 16 bit register
(SIPO, asynchronous reset) to use it as a component in another Serial
Multiplier code.
I have been struggling with 'U' output on my signal:
code:
library ieee;
use ieee.std_logic_1164.all;
entity ShiftRegister is
  port(A: IN std_logic_vector (15 downto 0);
       clk,load,reset: IN std_logic;
       Y: OUT std_logic);
end ShiftRegister;
architecture behavior of ShiftRegister is
signal tmp: std_logic_vector(15 downto 0);
begin
tmp <= (others => '0');
process (reset,clk)
begin
  if (reset = '1') then
    Y <= '0';
  end if;
end process;
process (load, A)
begin
  if (load = '1') then
    tmp <= A;
  else
  end if;
end process;
process (clk)
begin
if (clk = '1' and clk'EVENT) then
  Y <= tmp(0);
  tmp <= '0' & tmp(15 downto 1);
end if;
end process;
end behavior;
Test Bench:
library ieee;
entity tb_ShiftRegister is
end tb_ShiftRegister;
architecture behavior of tb_ShiftRegister is
component ShiftRegister
  port(A: IN std_logic_vector(15 downto 0);
       Y: OUT std_logic);
end component;
signal A: std_logic_vector (15 downto 0);
signal clk,load,reset,Y: std_logic:= '0';
begin
clk <= not clk after 10 ns;
DUT: ShiftRegister port map (A,clk,load,reset,Y);
process
begin
  wait for 0 ns;
  reset <= '1'; load <= '1'; A <= "1010101010101010";
  wait for 320 ns;
  --A <= "1111000011110000";
  --wait for 320 ns;
end process;
end behavior;
*PISO
correction!
Here is what I've managed to code (still no go). The processes do not
seem to return different Y values but I still get 'U'
library ieee;
       Y: OUT std_logic);
end ShiftRegister;
signal tmp: std_logic_vector(15 downto 0):=(others => '0');
signal F: std_logic:='0';
begin
--tmp <= (others => '0');
process (reset,clk,A)
begin
  F <= '0';
elsif (clk = '1' and clk'event) then
  F <= tmp(0);
else
  F <= F;
end if;
end process;
process (load,A)
begin
  tmp <= A;
end if;
end process;
Y <= F;
end behavior;
Omar Rashad wrote:
> but I still get 'U'
Now the question arises: What is 'U'?
'U'ndefined, 'U'seless, 'U'ncertain, 'U'ninitilized?
   wait for 320 ns;
Shouldn't you do anything with load and reset afterwards?
After having managed that you will encounter serious problems with this
here:
begin
tmp <= (others => '0');            -- tmp is ALWAYS reset to all zero!
process (reset,clk)
begin
    Y <= '0';
  end if;
end process;
process (load, A)
begin
    tmp <= A;                      -- ADDITIONALLY sometimes tmp gets the value of A
  else
    tmp <= (others => '0');        -- if not is is reset to zero ONCE MORE
  end if;
end process;
process (clk)
begin
  Y <= tmp(0);
  tmp <= '0' & tmp(15 downto 1);   -- ADDITIONALLY sometimes its shifted with a clock
end if;
end process;
end behavior;
All in all: you drive tmp from three sources. That will not work! it
will result in a collision. And
BTW: the very same is for Y! It is driven from two sources...
In fact you cannot reset Y because its the very same signal as tmp(0)!
Why should you need here a reset signal at all?
Try it that way and think hard about it:
  signal tmp: std_logic_vector(15 downto 0) := (others=>'0');
begin
  process (clk,load,A)
  begin
      tmp <= A;
    elsif (clk = '1' and clk'EVENT) then
    end if;
  end process;
  Y <= tmp(0);
end behavior;
: Edited by Moderator
Aren't all processes treated as concurrent statements within
architecure? So only when one of the elements in the sensitivity list
changes do they run again, correct? That means only processes with
changes in their SL will get re-evaluated. Do I understand this
correctly?
And the code that you provided (theoretically, I cannot simulate it now)
does not work as intended. This is because tmp is reset to A everytime
the process runs so we won't truly get the serial output of A, just
continuous A(0)'s.
Author: P. K. (pek)
> correctly?
From the point of view how the Simulator calculates the result of each
process this is correct, but: The other processes that are not
re-evaluated still drive the signals (with the same not re-evaluated
values as before).
In fact, it is only the simulator that makes use of sensitivity lists
(to know when it needs to calculate new values). The hardware that
results from synthesis just permanently "is there".
: Edited by User
Omar Rashad wrote:
> Do I understand this correctly?
Just for the simulation this is (nearly) correct. But in hardware each
process is realized in parallel to each other process and "it" will
drive its value all the time...
It works as far as my intention was: I load a value int the shift
register by assigning a value to A and setting load to '1'. AFTERWARDS
i set load to '0' and start clocking the data out. Got the trick?
And do you remeber my question:
>  wait for 320 ns;
I understand. But the assignment requires that Load remains 1 when we
are clocking out an output and 0 if we want to clear the register.
Which one?
> that Load remains 1 when we are clocking out
And how do you LOAD data to the shift register? And if load also
clears the register: what is the reset for?
By assignment I was referring to my assignment
Reset clears the output to zero regardless of load. When reset is zero,
content is zero if load is zero and is filled with Din when load is one.
That is why load and A are in a separate process that is sensitive to
both but not reset or clock.
Omar Rashad wrote:
> When reset is zero, content is zero if load is zero and is filled with
A very unusual behavior. For a pity there is no hardware inside a FPGA
able to handle such behavior...
> that is sensitive to both but not reset or clock.
You think the wrong way! You cannot control hardware stucture with the
sensitivity list. The sensitivity lust is only relevant for the
simulator.
Are you saying I cannot use both load and reset?
Can you show me a code you would write to describe a PISO 16 bit
register (clocked) ?
I did already. Tomorrow I will provide a simple testbench for it...
Ok, here we go.
My spec is:
1. when load is '1' then load the vector A to the shift register
2. when load is '0' then shift out the data bit LSB first through Y
And this is the result:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Piso is
    Port ( clk :  in   STD_LOGIC;
           load : in   STD_LOGIC;
           A :    in   STD_LOGIC_VECTOR (15 downto 0);
           Y :    out  STD_LOGIC);
end Piso;
architecture Behavioral of Piso is
  signal sr: std_logic_vector(15 downto 0) := (others=>'0');
begin
  begin
      sr <= A;
    elsif rising_edge(clk) then
      sr <= '0' & sr(15 downto 1);
    end if;
  end process;
  Y <= sr(0);
end Behavioral;
Using this testbench I get the waveform in the screenshot:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY tb_piso IS
END tb_piso;
ARCHITECTURE behavior OF tb_piso IS
    COMPONENT Piso
    PORT(
         clk : IN  std_logic;
         load : IN  std_logic;
         A : IN  std_logic_vector(15 downto 0);
         Y : OUT  std_logic
    END COMPONENT;
   signal clk : std_logic := '0';
   signal load : std_logic := '0';
   signal A : std_logic_vector(15 downto 0) := (others => '0');
   signal Y : std_logic;
BEGIN
   uut: Piso PORT MAP (
          clk => clk,
          load => load,
          A => A,
          Y => Y
   clk <= not clk after 5 ns;
   process  begin
      A <= x"5555";
      load <= '1';
      wait for 15ns;
      load <= '0';
      wait for 200ns;
      A <= x"CCCC";
      load <= '1';
      wait for 15ns;
      load <= '0';
      wait for 200ns;
      A <= x"F0F0";
      load <= '1';
      wait for 15ns;
      load <= '0';
      wait for 200ns;
      wait;
   end process;
END;
The PISO is synthesizeable and results in 16 D-Flipflops with
asynchronous clrear and preset inputs, which are controlled from A with
a little glue logic. See the RTL schematic for this result...
  • [vhdl]VHDL code[/vhdl]
