Xilinx 8.1 & Xilinx 14.7 Version will not compile my design
OP (Company: Scientech Technologies) #3856183
Hi.
I designed the processor DorQ which is attached. It compiles fine in
Quartus 2 but my business partners use Xilinx 8.1 & Xilinx 14.7 Version
and on these software, it shows errors which are also attached to this
thread.
Could someone please provide a solution to this problem. Is there a
setting we can change on Xilinx 8.1 & Xilinx 14.7 Version that will do
away with the error messages.
Thanks for your reply.
Guest #3858200
The message say, that there are two outputs are connected:
ac923: acff port map (wire1(2500 downto 2500), wire1(2501 downto 2501), wire0(2501 downto 2501), wire0(2500 downto 2500));
bc1579: bcff port map (wire0(2501 downto 2501), wire0(2502 downto 2502), wire1(2502 downto 2502), wire1(2501 downto 2501));
But your provided code is not human readable. Sorry, I can't help.
Did the error also occur, if you try to generate a bitfile?
Duke
Moderator (Company: Titel) #3858246
Lewis Mbuthia wrote:
> It compiles fine in Quartus 2
What target?
You use extensively inout ports inside a FPGA. But FPGAs don't have
bidirectional ports in them anymore. Thes also don't have a 'Z' inside.
So every bidirectional connection must be resolved at compile time to a
unidirectional mux-solution. That looks fairly tricky in the supplied
code...
> it shows errors which are also attached to this thread.
Errors messages in PNG format? Why not as raw text as they are
displayed in your computer?
1.png: the syntax check just tells, that theres no semicolon or comma
missing. Nearly useless...
2.png: "Synthesize failed" is NOT a error message, its just a final
result. Absolutely useless...
3.png: A multi-source means just: you connected two outputs together. Or
in more sophisticated words: you have more than one driver on this
signal.
I don't see a solution for your problem. The design looks incredibly
tricky. And it looks like it is not a design built for a FPGA.
Guest #3863134
WOW - That's what I call massive Crossposting. I thought, that the
people nowadays know, not to crosspost?
http://www.alteraforum.com/forum/showthread.php?t=46551
http://forums.xilinx.com/t5/New-Users-Forum/Xilinx-8-1-amp-Xilinx-14-7-Version-wiil-not-compile-my-design/td-p/535083
http://forums.xilinx.com/t5/General-Technical-Discussion/Xilinx-8-1-amp-Xilinx-14-7-Version-will-not-compile-my-design/td-p/536943
www.stackoverflow.com/questions/26563019/xilinx-8-1-xilinx-14-7-version-
embdev.net/topic/347939
Only the entry in edaboard I'm missing? [edit: found it, but as another
question. See below.]
And what the hack is DorQ??? I can find only these interesting articles
with naming such thing. Definitly worth the reading! Regarding to the
crossposting and the mail-address, I asume that this is also from you,
Lewis Mbuthia?
http://www.edaboard.co.uk/partnership-request-t527308.html
http://www.fpgarelated.com/comp.arch.fpga/thread/110054/partnership-request.php
The code looks like a prank to me. But definitly not as a accelerating
USB-Coprocessor. No explanation, what it is supposed to do. Whether it's
complete. Nor the explanation of existing and running configurations...
(I asume, there is no running configuration on a FPGA, and if there is,
it isn't doing, what the descriptions says.)
But it's also funny, to look further. Only one example of the
company-page scientechworld.com/careers.php : "At Scientech we have a
vision of where we want to go, and it's really exciting. [...]" :-)
Thanks for the funny workbreak!
Btw, it is often worth, to read the entries of embdev.net. ;-) (I'm
impressed about your patiance, Lothar, to answer many of those
questions! Good Job!)
 - ElKo
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
