Forum: FPGA, VHDL & Verilog Barrel Shifter
von Omar (Guest)
This is a source code for a linear shift barrel shifter (unclocked). I'm
having trouble converting the binary input into an integer. Please view
my code and error and tell me what I'm doing wrong.
BTW, the source and the tb both compile successfully through vhdlan.
: Edited by Moderator
Omar wrote:
> Please view my code
Pls post your code once more as a vhdl attachmet. Or insert it into your
posts text surrounded by the vhdl tokens (see the formatting options
just a very few lines under
And you can also copy and paste the error messages.
I will not look at some pictures and retype all the code for a hint (and
I have at least 4 of them...).
von Omar (Guest)
Source code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity barrelshifter is
port(A,B: IN std_logic_vector(15 downto 0);
     D: IN std_logic;
     ShiftOut: OUT std_logic_vector (15 downto 0));
end barrelshifter;
architecture behavior of barrelshifter is
begin
process (A,B,D)
variable shift:integer range 0 to 65535:= to_integer(unsigned(B));
variable append: std_logic_vector (shift downto 1);
variable V: std_logic_vector((shift+15) downto 0);
  begin
  for i in 1 to shift loop
    append(i) := '0';
  end loop;
  if D = '1' then
    V := append & A;
    ShiftOut <= V(15 downto 0);
  else
    V := A & append;
30
    ShiftOut <= V((shift+15) downto shift);
31
  end if;
32
end process;
33
end behavior;
Test bench
library ieee;
entity tb_barrelshifter is
end tb_barrelshifter;
architecture structure of tb_barrelshifter is
component barrelshifter
       D: IN std_logic;
       ShiftOut: OUT std_logic_vector(15 downto 0));
end component;
signal A,B,ShiftOut: std_logic_vector(15 downto 0);
signal D: std_logic;
begin
DUT: barrelshifter port map(A,B,D,ShiftOut);
process
begin
wait for 0 ns; A<= x"0001"; B<=x"0002"; D <='0';
wait for 20 ns;
end process;
end structure;
configuration tb_barrelshifter_con of tb_barrelshifter is
30
for structure
31
end for;
32
end tb_barrelshifter_con;
Lothar Miller wrote:
> insert it into your posts text surrounded by the vhdl tokens
[vhdl] VHDL Code [/vhdl]
Ok, I did it for you. Now lets start:
Never use both of the arithmetic libraries together:
Use the numeric_std and the conversions in it only!
Otherwise you may have double defined datatypes in your VHDL code.
This could be written gerneric in one line:
    append(i) := '0';
  end loop;
Do it this way:
  append := (others=>'0');
Where is this "15" from?
And why should you try to shift a 16 bit vector 65536 times?
The actual problem is this here:
This here is not possible, because shift must be constant because (x
downto y) only accept constants. But shift is evaluated out of B, and
B istn't constant:
variable append: std_logic_vector (shift downto 1); -- shift must be constant!
And also the begin and the end of a loop must be constant:
  for i in 0 to shift loop
Why do you do the thing so circiutous?
You must look at the problem not with a programmers "software view", but
with a sense for the hardware you want. So there is the quuestion: what
is a barrel shifter? Fairly easy: a big multiplexer.
And after knowing what you need you must describe this big multiplexer.
Thats all.
You nearly got the way by shifting the input in a bigger vector and
cutting out the slice you want (thats the multiplexer actually).
So first is to say: a 16 bit vector can be shifted either 16 bits the
one or 16 the other way. Then it may look like this:
library ieee;
port(A: IN std_logic_vector(15 downto 0);
     B: IN std_logic_vector(3 downto 0);
     D: IN std_logic;
end barrelshifter;
begin
  process (A,B,D)
  variable s : integer range 0 to 15;
  variable r : std_logic_vector(15 downto 0);
  begin
    s := to_integer(unsigned(B));
    r := (others=>'0');
    for i in 0 to 15 loop
      if D = '1' then r(s+i) := A(i);
      else            r(i) := A(i+s);
      end if;
      if (s+i =15) then exit; end if;
    end loop;
    ShiftOut <= r;
  end process;
end behavior;
Its fine, I tested it with this TB:
library ieee;
     D: IN std_logic;
end component;
signal B: std_logic_vector(3 downto 0);
signal A,ShiftOut: std_logic_vector(15 downto 0);
begin
process
begin
  A<= x"8001";
  B<= std_logic_vector(to_unsigned(i,4));
  D <='0';
  wait for 20 ns;
30
end loop;
31
32
wait for 200 ns;
33
34
35
  A<= x"8001";
36
37
  D <='1';
38
  wait for 20 ns;
39
end loop;
40
41
wait for 200 ns;
42
43
end process;
44
end structure;
von Omar (Guest)
Thanks for your input. I have tried implementing your code with one
minor change (I left B as an 8 bit vector because that is the assignment
requirement - for some reason): This is my code:
library ieee;
     D: IN std_logic;
end barrelshifter;
begin
process (A,B,D)
variable shift:integer range 0 to 65535;
variable V: std_logic_vector(15 downto 0):= (others=> '0');
  begin
  shift:= to_integer(unsigned(B));
  for i in 0 to (15-shift) loop
    if D = '1' then
      V(shift+i) := A(i);
    else
      V(i) := A(shift+i);
    end if;
    if (shift+i = 15) then
    exit;
    end if;
  end loop;
30
  ShiftOut <= V;
31
end process;
32
end behavior;
With this test bench
library ieee;
       D: IN std_logic;
end component;
begin
process
begin
wait for 20 ns; A<= x"0050"; B<= x"0010"; D <= '1';
wait for 20 ns;
end process;
end structure;
30
31
32
for structure
33
end for;
34
When I run the TB my ShiftOut is an undeclared most significant bit
followed by zeros.... I do not get it...
Omar wrote:
> I do not get it...
No comment!
Didn't you read my post? Or didn't you understand it?
Omar wrote:
> I have tried implementing your code with one minor change
You did some minor changes:
If you don't do the
A process isn't like a function call in software! It is evaluated bay
the simulator each time one of the signals in the sensitivity list
changes. If you don't do an explicit reset of V then it will memorize
its value from the last evaluation! So you MUST reset it to zero the way
I did!
And this here?
Also just a minor change?
Have a look, what 'U' excalty means!
Omar wrote:
> - for some reason
If you shift a 16 bit vector more than 15 times, then the result is all
zero.
Try this:
library ieee;
     D: IN std_logic;
end barrelshifter;
begin
process (A,B,D)
variable V: std_logic_vector(15 downto 0);
  begin
  V    := (others=> '0');
  if shift <16 then
      if D = '1' then
        V(shift+i) := A(i);
      else
        V(i) := A(shift+i);
      end if;
        exit;
30
      end if;
31
    end loop;
32
  end if;
33
  ShiftOut <= V;
34
end process;
35
end behavior;
Now the simulation looks fine (screenshot). Just the stimuli is
nonsense. Think about it!
And for the future: if somebody would present me a fully functional
sample and I would do "just minor changes" and afterwards it would not
run anymore, then I would try to figure out myself, what change caused
the problem. This process is called "learning"!
von ebrahim (Guest)
Design and implement a Sequence Detector.
1- Subject: FDesign a Sequence Detector.
2- Function requirements: FThe detector has an input terminal X,
signal is detected for the serial input binary sequence, the detector
has an
output terminal Z, when a binary sequence have 4 consecutive 1, the
output is 1, the output of remaining cases is 0. For example:
X= 1101111110110
Z= 0000001110000
von Duke Scarring (Guest)
New problem, new topic please!
