Forum: FPGA, VHDL & Verilog Audio Interfacing with FPGA
Author: Jack Born (Guest)
I would like to connect 3.5 mm audio jack to nexys 3 board but have no
idea how to do so.. I am a beginner with regards to fpgas and vhdl
coding
Why? For what reason?
> but have no idea how to do so..
Fist step has absolutely nothing to do with FPGAs or VHDL: you must
connect an AD converter to the FPGA.
> I am a beginner with regards to fpgas and vhdl coding
Then don't start with such a fairly demanding task (for a beginner).
Instead start with the "blinking led", the "chasing light", and some
RS232 and VGA, just to learn the very basics of hardware design. If you
do not, you will crash...
Yes I was thinking of buying an ADC converter as the one shown.  I know
it sounds noobish but am not sure how to connect the audio jack's left
and right channels to the respective data 1 and data 2 pins.
Jack Born wrote:
> not sure how to connect the audio jack's left and right channels to the
Not at all. Read the documentation for the ADC module, then you will see
that you have to connect the audio source to P1 and P3. Data1 and Data2
are the digital serial ADC outputs.
: Edited by Moderator
But how can a 3.5 mm jack be connected to 2 ports simultaneously?
It may be a stereo jack...
http://en.wikipedia.org/wiki/Phone_connector_%28audio%29
yes but how do i connect the stereo jack with the adc converter shown in
the picture?
> the picture?
Get a soldering iron and start. Maybe you must add a offset voltage to
get the audio signal into mid range of the adc input:
The AD1 converts an analog input signal ranging from 0-3.3 volts
to a 12-bit digital value in the range 0 to 4095.
So you will need something like this here:
                o
               10k
In Left   --||--o---- P1 of ADC
         470n   |
               10k
               GND
In GND ---.
         GND
                o 3V3
               10k
In Right  --||--o---- P3 of ADC
         470n   |
               10k
               GND
> with the adc converter shown in the picture
Its an AD1 module from Digilent. Just WRITE down this little fact
instead of digging in the mud for over 2 hours just to find out a little
snippet of information...
actually thought i couldn't mention any brands, thanks I will dig around
a bit and let u know how I got off
Author: P. K. (pek)
Maybe this could be a solution for you (ADC included...):
http://uk.farnell.com/digilent/210-191/peripher-mo...
thats converting digital to analog not analog to digital :/
Author: uwe (Guest)
Author: Hobbyorganist (Guest)
The Nexys has 4 PMOD connectors. There are a number of audio IFs out to
purchase in PMOD standard from Digilent.
  • [vhdl]VHDL code[/vhdl]
