Forum: FPGA, VHDL & Verilog Serial signal in DAC
Author: angelo (Guest)
Hi everyone,
I'm writing a code to simulate a 12-bit dac. The behavior is quite
simple:
A serial digital input receive datas ( 32-bits word with the 12 bits to
convert + don't care bits + command) and the 12 bits word is converted
every 32 clk.
My first try was to create a signal data_input: std_logic_vector (31
downto 0) and convert only the 12 bits I want. But this not exactly the
right thing.
I thought a clk counter is necessary and others things but can't find
out...
Can you give me some advice to get over it please?
Author: Jürgen Schuhmacher (engineer)
Basically you will need two clocks since the left side domain is totally
analog and independent from the sampling domain. Practically you will
work with ps resoultion in order to feed your DAC with data. Furthermore
you will need a kind of anti aliasing filter for the incoming data
stream to simulate aliasing which will occur in reality. Next steps are
non linearity and noise.
> and the 12 bits word is converted every 32 clk.
Into what?
> signal data_input: std_logic_vector (31 downto 0)
a 32-bit input doesn't match
What input do you have? What output do you need? What is the actual
problem?
I wrote this code in a first time:
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.numeric_std.all;
entity dac is
  generic (data_width : integer;
     SDI_width  : integer
     --REF        : real
  port(  REF   : in  real;
    SDI   : in  std_logic_vector (SDI_width - 1 downto 0);
    SDO   : out std_logic_vector(SDI_width - 1 downto 0);
    SCK   : in  std_logic;
    CLR   : in  std_logic;  -- low level active
    CS_LD : in  std_logic;   -- '0': CS / '1': LD
    LDAC  : in  std_logic;  -- low level active (always '1' here)
    Vout  : out real
end dac;
architecture archi of dac is
signal data      : std_logic_vector(11 downto 0);
signal data_real : real;
begin
  data <= SDI(15 downto 4);
  P1: process(SCK, data)
  constant Tclk : time := 10 ns;
  begin
    data_real <= (real(to_integer(signed(data))));
    SDO <= transport SDI after Tclk*32;
    if (CLR = '0' or CS_LD = '0') then
      Vout <= 0.0;
    elsif (SCK'event and SCK = '1') then
      Vout <= data_real/(2.0**data_width) * REF;
    end if;
  end process;
end archi;
The problem is I have to connect the signal SDI to an 1 bit signal.
Which is not possible if SDI is a std_logic_vector.
: Edited by Moderator
SDI is not a vector at all! It is a simple 1 bit std_logic input.
And together with LD it is very clear what has to happen here:
1. LD is set to '0'
2. with SCLK bits from SDI are shifted into a 32 bit register in the
DAC
3. with LD set to '1' the register is evaluated
So it may look like this:
    SDI   : in  std_logic;
    SCK   : in  std_logic;
    signal   inreg : std_logic_vector (31 downto 0);
    inreg <= inreg(30 downto 0) & SDI when rising_edge(SCLK) and CS = '0';    -- shift data in, assuming MSB first
    data <= inreg(15 downto 4) when rising_edge(CS_LD); -- transfer interesting part of vector to analog processing
Got the idea?
  • [vhdl]VHDL code[/vhdl]
