Forum: FPGA, VHDL & Verilog State Machine with accumulator in VHDL
Author: Sony (Guest)
Hello,
    I need a State Machine in VHDL, that receives a start, then "read" a
8-bit value, then sums it with the accumulated values(initialy 0), then
put the result in a register, and then do all of it again, since the
scan of the 8-bit value, until the register with 16-bit is totally
filled. Can someone help me with this?
PS.: Each of these steps, after a clock signal.
Author: Bitflüsterer (Guest)
Take your description and elaborate. It's not really far from the
result.
Consider the following questions:
What is "a start"? A pulse? A level?
What is the disctinction between your "device" and an ordinary counter?
If there is any? If there is indeed none (or only a slight one), try to
implement a counter.
What does "... until the register with 16-bit is totally filled."
acutally mean? From a theretical point of vier: How many 8-Bit unsigneed
number (are they?) may you add before a 16-Bit unsigned overflows?
Oops. Some typos:
auctually mean? From a theoretical point of view: How many 8-Bit
unsigneed
Sony wrote:
> "read" a 8-bit value
From an 8 bit port?
And then? Discard the value and wait for the next start signal?
Or let it say the other way: what is this for? Is it just homework, or
is it a part of something else? If the second: what is it part of?
  • [vhdl]VHDL code[/vhdl]
