Forum: FPGA, VHDL & Verilog Pointer std_logic_vector
Author: Kim (Guest)
Hi
I am stuck with a problem in vhdl and hope someone can help me solving
this.
I am trying to implement a driver on a Atlys Spartan-6 board to read out
data which comes in via HDMI. I allready located the variable
(std_logic_vector(23 downto 0)) which carries the signal i want to
export from the Atlys driver.
The new driver has as input a variable (unsigned(7 downto 0)) in which
only the adress of my datastream is inserted.
My problem now is to set a pointer between those two variables. I
believe I somehow have to define my vector as access type, but however i
am trying to do this, it won't work.
I hope someone can give me a hint how to solve this.
Author: db8fs (Guest)
Adressing some physical connections in your FPGA won't work, so I guess
your Is-Access-approach won't work as expected.
So what do you want to achieve? Do you want to extract a value from your
24-Bit input signal (e.g. input(15 downto 8) ) and assign this 8 to some
other module?
What I'm talking about:
entity test is
  Port ( clk : in  STD_LOGIC;
           reset : in  STD_LOGIC;
           input : in  STD_LOGIC_VECTOR (24 downto 0);
           output : out STD_LOGIC_VECTOR( 7 downto 0) );
end test;
architecture Behavioral of test is
begin
  PROCESS (clk)
  BEGIN
    if RISING_EDGE( clk ) then
        output <= input(15 downto 8);
    end if;
  END PROCESS;
end Behavioral;
Is this approximately what you're trying to do? Note that I didn't care
about type conversions like:
foobar <= std_logic_vector(  resize( output(7 downto 0), output'length) );
Sorry, if I can't help you further, my HDL has gotten a bit rusty in the
last 5 years...
Author: Kim (Guest)
Thank you for your help so far, but in this case you are describing only
a quarter of the information is beeing sent.
Here is a little part of the drivers code:
library work;
use work.dds_pack.all;
use work.convert_pack.all;
  entity ws2812_LED_chain_driver is
    generic (
      SYS_CLK_RATE : real := 50000000.0; -- underlying clock rate
      ADR_BITS     : natural := 8; -- Must equal or exceed
BIT_WIDTH(N_LEDS)+2.
      N_LEDS       : natural := 8  -- Number of LEDs in chain
    port (
      -- System Clock, Reset and Clock Enable
      sys_rst_n  : in  std_logic;
      sys_clk    : in  std_logic;
      sys_clk_en : in  std_logic;
      -- Selection of color information
      c_adr_o    : out unsigned(ADR_BITS-1 downto 0);
      c_dat_i    : in  unsigned(7 downto 0);
      -- Output
      sdat_o     : out std_logic
    end ws2812_LED_chain_driver;
As you can see the color information is a vector[7 downto 0].
The datastream for the input is a STD_LOGIC_VECTOR (23 downto 0), for
each color 8 bit are needed.
I am quite a VHDL noobie but i cant believe that there is no way to
adress this 24-bit Variable directly. I mean otherwise the entire driver
doesnt work.
Author: Lattice User (Guest)
> doesnt work.
You are thinking in software terms.
VHDL is a hardware description language and not a programming
language. What you call a "driver" is the description of a hardware
module which is build inside the FPGA by the synthesiser. The
STD_LOGIC_VECTOR is just a bunch of connection wires to connect this
module, and not some memory variable with a address.
> describing only
Well, I hoped to avoid confusion by omitting additional signals - I
guess that's the task of example code.
> library work;
>     generic (
>     port (
>       -- Output
> doesnt work.
As Lattice User already mentioned, your HDL synthesis generates you a
Logic circuit, in especially a set of logical functions that gets
connected by some switching logic. A 'Signal' in HDL is a physical wire
connecting subcircuits. How do you want to address wires? You're working
on register-transfer-level, no memory-like-addressing is available here
using VHDL.
If you still can't imagine, how HDL works: Try to build a circuit with
74*-NAND-ICs in a breadboard - how would you solve your problem there.
You could also use the Schematic Editor to get some understanding about
the results you're getting from your synthesis.
In order to solve your task, you probably have to describe your own
address decoding logic that maps the memory address to a value. That
means you have to write your own indirection logic, if the design you're
using doesn't already have such component.
db8fs wrote:
> A 'Signal' in HDL is a physical wire connecting subcircuits.
A signal (or even a variable) in VHDL may be a register also: just
involve a clock to get a register. And it may be a latch, mostly a
undesired one...
> undesired one...
You're absolutely right, of course the synthesizer has to resolve
time-dependencies and will create sequential logic for it. My intention
was to point out the different layers of computer architecture and the
differences in designing for the algorithmical level and for
sub-algorithmical levels like the Register-Transfer-Level.
Unfortunately the hardware design gets confused by things like SystemC
or other HighLevel-Synthesis-Tools. They promise to be easy and usable
like ordinary programming languages, but they still need to be used with
the mind or the view of a hardware designer placing logic circuits. And
even VHDL/Verilog gives the user a lot of possibilities with the risk
for the beginner of creating non-sythesizable descriptions.
  • [vhdl]VHDL code[/vhdl]
