Forum: FPGA, VHDL & Verilog How to decide the maximum frequency on FPGA?
Author: Yang Zheng (Guest)
I want the circuit run as fast as possible on FPGA, except the
limitation of the device, how to decide the maximum frequency for FPGA?
Thanks and Regards,
Author: P. K. (pek)
Depends mainly on your design, and on the FPGA (type, speed grade) as
well.
Define realistic but aggressive constraints (based on the FPGA datasheet
and/or your requirements) and check the STA (static timing analysis)
after synthesis:
- If the timing is met, go for a more aggressive setting.
- If the timing is not met do one (or more) of the following:
  - Relax the constraints.
  - Reduce the number of logic levels (between FFs) in your design.
  - Introduce pipelining registers.
Then restart the whole thing (it's iterative) until you are happy with
the result.
Thank you.
Author: Jürgen Schuhmacher (engineer)
hm, constraints are usually derived from specifications and functional
demands, so one can hardly release them. The operation frequency of the
FPGA is usually more or less directly linked to input data streams from
chips, so one cannot go with lower freqs. On the other hand there is no
demand for a maximum frequency.
Practically there is a range of a sensible operation frequency for every
FPGA type. For e.g. a Spartan 6 device, one can reach 150MHz easily and
up to 175 MHz with some work.
Author: P. K. (pek)
I agree with you in a regular project environment, but the question
seems to me somewhat more academic in a way to try the FPGA (the
specification here is "as fast as possible").
Furthermore, only the interface timings might be fixed or have a clear
maximum. That does not prevent you to have an internal master clock
running as fast as possible with your given circuit (of course you have
to bother about clock domain borders, but that's another story).
  • [vhdl]VHDL code[/vhdl]
