Forum: FPGA, VHDL & Verilog is not declared
Author: Dmitriy Kraftig (kraftig)
Hi, can you help me? I am using Xilinx ISE 14.3 and VHDL. And if I
write:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity system_core is
  port( I_SYSTEM_CLK_50M : in std_logic;
      I_SYSTEM_RST    : in std_logic;
      O_SYSTEM_CLK_1HZ : inout std_logic;
      O_SYSTEM_SEG_OUT : out std_logic_vector (7 downto 0):=(others=>'0')
end system_core;
entity div_50M is
  port( I_CLK_50M : in std_logic;
      I_RST     : in std_logic;
      O_1HZ     : out std_logic);
end div_50M;
entity seven_seg is
  port ( I_EVENT_1HZ : in std_logic;
       SEG_OUT : out std_logic_vector (7 downto 0):=(others=>'0'));
end seven_seg;
I have many errors, as
Parsing architecture <arc0> of entity <system_core>.
Parsing entity <div_50M>.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 35: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 36: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 37: <std_logic> is not declared.
ERROR:HDLCompiler:854 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 34: Unit <div_50m> ignored due to previous errors.
Parsing architecture <arc1> of entity <div_50m>.
ERROR:HDLCompiler:374 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 41: Entity <div_50m> is not yet compiled.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 42: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 43: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 51: <l_led_ctr> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 53: <l_led> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 54: <l_led_ctr> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 52: <l_led_ctr> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 56: <l_led_ctr> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 50: <i_rst> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 49: <i_clk_50m> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 60: <o_1hz> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 47: <i_clk_50m> is not declared.
Parsing entity <seven_seg>.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 66: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 67: <std_logic_vector> is not declared.
ERROR:HDLCompiler:854 - "C:\Users\BAT\Desktop\xilinx\Exapmles\vhdl_test\first_module.vhd" Line 65: Unit <seven_seg> ignored due to previous errors.
But if I write:
library IEEE;
end system_core;
entity div_50M is
end div_50M;
entity seven_seg is
end seven_seg;
I have no errors, why?
Before EACH entity you must declare the used libraries. That's VHDL...
Usually that's easy done, because each entity has its own vhdl file.
But: up to now no one of your entities has an architecture. And
therefore it has no function.
thank you!!!
  • [vhdl]VHDL code[/vhdl]
