Forum: FPGA, VHDL & Verilog looking for a MIPS1 multi cycle, not pipelined
Author: Legacy My (Company: my) (legacy)
hi
i am looking for a mips1 ISA implementation (in VHDL, if possible) that
is multi cycle and not pipelined
is there anything around ?
Author: Strubi (Guest)
I am not aware of any multi cycle MIPS variant, you might want to check
out the 'ZPU small' instead. It has pretty decent GCC support (however
it may need a bit of string size bug patches when compiling with recent
toolchains).
Why would you want to pull apart the MIPS pipeline? If it is to save
resources, the ZPU is IMHO the better option.
Greetings,
- Strubi
Author: greg (Guest)
MIPS1 is pretty simple, maybe you can implement it yourself? There are
very few instructions and no particular surprises.
> check 'ZPU small'
it is a stack machine, i hate such a stuff
multi cycle is 1:5 inflated versus the pipeline version, that is
acceptable if you are not thinking about "performance" instead of "the
less complexness"
about complexness, removing the pipeline means
- removing the hazard detect unit
- no hazards, stall, alee
- less code, to be written, verified, synthesized and tested
- no branch prediction needed
- no strong slot delay with branches
that means the less issues with gcc-mips1's obj code
that also means less difficulties if you want to toy with the core, for
example if you want to insert a debug unit that dump out registers on S4
cycle
S0: fetch
s1: decode
s2: execute
s4: mem
s5: writeback    <----- registers dump, from r1 to r31 + PC, EPC
or if you want to realize a "fault toy tolerant" version of the CPU, or
such an hobby stuff
everybody says that, nobody has posted code: is it so really easy ? why
i can't see nothing so easy on OpenCores ? Everybody with
"alpha/beta/not-stable" version of hyper complex MIPS-pipelined never
finished/never-validated'toy …
writing and validating a Softcore requires effort, the more complex you
write your Softcore the more effort it will take to you in order to be
validated!
Keep it simple, especially for time limited hobby purpose !
btw, i am asking MIPS1 multi cycle, i do not want anything else, and
yes, in case i will write myself, just i do not want to re-invent the
wheel, so if such a core is existing i am pretty happy to save my
development time
: Edited by User
> Everybody with
Yeah, a pipelined core is probably at least an order of magnitude harder
to do than a simple multi cycle one. A multi cycle core is just a big
but simple state machine.
Author: René D. (Company: www.dossmatik.de) (dose)
Legacy My wrote:
> hi
A pipelined Core ISA1 is available.
http://www.dossmatik.de/mais-cpu.html
exactly, this is the problem: MAIS is pipelined, that means good,
excellent, by "too complex for me", i am looking for a not-pipelined
multi-cycle.
to be honest i have already implemented something mono-cycle, but it is
very ugly and - as i have written - i do not want to reinvent the wheel,
i am looking for a multi-cycle because it is perfect for my purposes, if
i will not find it … no problem, i will try to evolve my
ugly-actual-toy-project
in short, i do not want a full MIPS_1 core, i want a toy-core, easiest
for the most, just to do cool experiments
my purpose is doing experiments, i do not want to implement a core, but
i need it, and i need it the most simple it can be
@Strubi
the CERN has released a custom version of LM32, which is a RISC core
plus devices, in short a tiny & smart SoC that is light years ahead the
ZPU.
unfortunately it is not MIPS compliant, its … a different core with a
completely different ISA. It's RISC, off course, but it is not MIPS.
also, you can see the OpenCores/Atlas, which is a RISC 16bit with an
incredible documentation and a well written code plus a brilliant
implementation of short time context switch in CPU space.
i was impressed by it, excellent code, great documentation, funny
assembly toolchain (the gcc/Atlas is … underdevelopment as far as i
understood, while gcc/LM32 has already a working port, tested and
validated) but … it is not what i am looking for.
: Edited by User
just a few comments:
The MIPS1k doesn't do that anyway.
You'd have to emulate the Branch delay slot in the multi cycle variant,
too.
The LM32 arch is nice, but does not beat the ZPU in terms of code size
and compactness. I agree that stack machines are kinda dirty when it
gets to debugging (GDB just isn't made for it), but on an FPGA, stack
machines with switchable window tricks open up a few nice possibilities
at similar speed marks.
If it's a toy CPU, I'd recommend to go ahead and write your own. I've
made very good experiences with MyHDL concerning CPU design and
verification.
I have played with MIPS16 using abstract microcode instructions (multi
cycled emulation, basically), but it is not synthesizeable (yet), and I
guess that's not what you're looking for.
Cheers
- Strubi
yes, mips R1000 and R2000 don't, but R3000 does it (and they are both
MIPS_1 about ISA, they differ about implementation, also the R3K adds
caches, that is … an other source of more speedup and more complexity),
especially if you add the pipeline!
with pipeline you have to speculate about every conditional branch: only
two choices are possible and only one choice will be taken, so you have
speculate, and in case you have speculated to the wrong choice well ..
you have to stall the pipeline, trash all the work it has done, and then
you have … to reload the cpu.reg.PC to the correct position, to fetch
the correct instruction, and and to go on
PowerPC has a very deeply issue about it, IBM guys call it "the EIEIO
instruction" that is required to force a pipeline stall and flush in
order to be sure about the I/O operation: what i thing about it ? Let me
say, i hate this about PowerPC!
about pipeline, the less stages the pipeline has, the less penalties you
have to pay with wrong choices about the branch prediction because you
have the less job to be trashed and reloaded: this may speed up
performances about conditional branches (the less penalties means more
instructions completed with success), but makes your design much more
complex, especially if you do dynamic branch prediction with involves
statistical analysis and such a stuff.
the pretty easiest solution of pure foolishness (which has been
practically used in cheap commercial microcontroller RISC like,
something like … Microchip PIC) is to assume that a conditional-branch
will not ever take the true-branch (or the false one) and … being ready
to stall the pipeline and to reload jobs, in case this prediction is
wrong: you get
the 50% of probability to do the right things, or the wrong things
saving up to the 60% of the complexity :D
btw, i do not want all of this complexness, i can accept a ratio 1:5
about MHZ:completed instruction for time
50Mhz -> pipelined MIPS can do 50.000.000 instructions/sec
50Mhz -> multicycle MIPS not pipelined can do 10.000.000
instructions/sec
in short, my 50Mhz clocked fpga is emulating a CPU that looks like a
10Mhz RISC (that seems less the performance you can get from a CISC, but
… who cares about that ? 10.000.000 instructions/sec are still great for
my hobby)
> too.
yes, of course, but it is an "emulation", it is not as "critical" as in
the pipelined version, that means the less complexity
also, if you gcc-compile with "-O0" you will always get
branch-delay-slot, that means every conditional/unconditional branch is
always stuffed with NOP, the compiler will always put a NOP after a
branch, that's cool and simplifies the design.
the "-O2" cflag is the most critical flag about gcc and you MUST take
care about the implementation: the compiler will try to do the less
branch-delay-slot it can do, so … you have to be very very careful about
the hardware design, especially about "alee" and "hazards" in the
pipelined version
> and compactness.
mmm, the Truth is … no RISC core can have the code density of CISC, for
example a MC6809 has the best code density all over the whole, but it is
CISC, it has complex ISA, and … it eats a lot of resources on FPGA.
i got system09 and i was playing with it, from the assembly point of
view (i mean as firmware guy) i love CISC machines, especially the
motorola 6809 and 68000 family because the make the programming activity
much more full of pleasure than RISC, unfortunately CISC … are
frustrating a lot in case you want to synthesize them in HDL/RTL
btw, the ZPU is a trade off of compactness and complexity, and it is
also a stack machine that consumes the less resources on fpga, and it
may consume the less iram (instruction ram), but its code eats a lot of
dram (data ram), especially for its soft registers
> but on an FPGA, stack machines with switchable window tricks
> open up a few nice possibilities  at similar speed marks.
yeah, like the "forth1 CPU" used in my GameDuino-v1, this shield has
been shipped with spartan3-250 fpga and a simplified "forth1 CPU" has
been put in it in order to provide you with a sort of GPU  … that sounds
"cool" but i can assure you i am hating it very so much than i have
switched to GameDuino-V2 which has an ASIC GPU with a RISC-custom-closed
machine inside :D
ZPU is obviously better than forth1, but … let me say: i hate every
stack machine!
> verification.
good advice, today i have experimented ghdl+gtkwave and i have done the
earliest patches to put my mono-cycle-toy-softcore into multi-cycle: it
seems working, obviously i can't believe it (i can't be so lucky and
skilled), but i have already got good experiences, a lot of more skills,
and fun =)
: Edited by User
about pipeline and IO, the PowerPC EIEIO:
form IBM PowerPC ISA vol1:
"Enforce In-Order Execution of I/O, or EIEIO, is a machine code
instruction used on the PowerPC computer processor which prevents one
memory or I/O operation from starting until the previous memory or I/O
operation completed. This instruction is needed as I/O controllers on
the system bus require that accesses follow a particular order, while
the CPU reorders accesses to optimize memory bandwidth usage."
here a freescale doc
-> http://cache.freescale.com/files/32bit/doc/app_not...
: Edited by User
Author: Michael Engel (Guest)
In case you're looking for a really small (mostly) MIPS-I ISA
implementation in synthesizable Verilog (built for Altera FPGAs), you
might be interested in U Toronto's "Supersmall" softcore:
http://www.eecg.toronto.edu/~jayar/software/SuperS...
IIRC, the SuperSmall core is not pipelined. However beware - this is a
bit serial implementation of MIPS-I, so it will also be super slow.
However, it can be scaled down to use only 115 Stratix III ALMs
(Adaptive Logic Modules).
-- Michael
nah, it is now compliant for my purposes
- it is written in Verilog, i do not want this language, first i do not
like it at all, and second i can simulate only VHDL (i am using
ghdl+gtkwave)
- it is serialized, everything is 1 bit, n times repeated, that is not
acceptable for my actual debug-cpu module (1)
(1) i have designed a debug module with uses a sequencer in oder to dump
cpu's registers by hardware, this module is scheduling the CPU cycles at
reduced frequency in order to handle the debug-uart-tx which is running
at 115200bps, that means 115.2 Khz.
I did something like that
50Mhz physical clock -----> sequencer ---> frequency divisor ---> soft
core's clock
also, in the soft core i have 5 cpu cycles
cpu.cycle0 - fetch
cpu.cycle1 - decode
cpu.cycle2 - execute
cpu.cycle3 - I/O
cpu.cycle4 - write back <---- the sequencer dumps registers here
the dumper has 36 blocks to be transmitted to host, each block is
composed by 4 byte ASCI, 4 byte of data, plus other 2 bytes for CR & LF
{ identifier (ASCII, 3byte), separator (ASCII, 1byte), uint32_t (4 byte
hex), CR, LF}
e.g. {'R','3','1',':',xx,xx,xx,xx, 0a, 0d}
that means the debug-uart-tx has 8+2 bytes to be transmitted for every
cpu registers
32 cpu-registes + PC, EPC, and other stuff, for a total for 36 blocks
i have already implemented this "engine" and the whole is currently
working on my Digilent board s3e500.
as "cavia" i am using a modified toy-version of my previous mono-cycle
MIPS1 soft-toy-core that has become
- multi cycle
- with everything strongly synchronized with 5 cpu cycle
Having a serialized CPU means … to adapt this scheme again and it has no
sense for me.
: Edited by User
Legacy,
not liking Verilog is one thing - however, most open cores nowadays are
written in Verilog, so you are going to restrict your options
significantly. However, free and open source tools such as iVerilog and
Verilator (which both work with gtkwave) are available for Verilog, too,
so that should not relly be a reason not to use this HDL.
However, I don't want to start an HDL war here. I just wanted to give
another link to a MIPS implementation that has not been discussed in
this thread so far - the eMIPS from Microsoft (MS Research, it even
comes with a complete NetBSD (!) port):
http://research.microsoft.com/en-us/projects/emips/
Again, this is written Verilog and pipelined, so it may not fit your
needs. What is especially interesting about the eMIPS is that you can
extend the processor by dynamically loading/unloading
application-specific circuits. Such extensions may add specialized
instructions to the processor, security monitors, debuggers, new on-chip
peripherals. One can load dynamically and plug into the stages of the
eMIPS pipelined data path, to extend the core instruction set of the
microprocessor.
Just some food for thoughts - this won't help with your actual problem
at hand, but maybe it gives some inspiration for your future work.
-- Michael
a MIPS project done by Microsoft research: simply unbelievable, and very
interesting ! Giano seems very powerful. I will read their papers in my
free time.
just a question, why Verilog instead of VHDL ? Why should i prefer it ?
Any good reason ? I mean, why do you prefer it ?
Verilog seems to find more use in the industry nowadays and it seems
more universities are currently teaching it. VHDL is mostly used in
European companies (and some universities) - which seems a bit strange,
since its development was initiated by the US ministry of defence IIRC.
From what I've seen, there are simply more open source hardware projects
written in Verilog. In theory, the language shouldn't matter, both are
on a roguhly similar description level and interfacing using
signals/ports is easy. Unfortunately, mixing VHDL and Verilog using free
simulation tools doesn't seem to be that easy. With Xilinx' toolchain
and ModelSim, it's rather easy, but that won't help you, again.
Btw., I do not have a HDL preference myself, I tend to be pragmatic and
use what's available. In fact, I used to teach my students SystemC -
which also seems to be a bit of a dead end right now (and there are no
really great synthesis tools IMHO), but the trend seems to go towards
SystemVerilog.
Anyways, the Microsoft eMIPS project has intrigued me since I read about
it some years ago. It was easy to get it to work on a Xilinx Virtex 5
XUP board and it seems well written and documented. However, I didn't
find the time to do a lot with it so far. The guys who worked on that
project are definitely nice and helpful. It's a bit of a shame that the
eMIPS didn't get much response.
  • [vhdl]VHDL code[/vhdl]
