Forum: FPGA, VHDL & Verilog Servomotor. PWM and VHDL
Author: Soko Loko (Company: sokoban) (gilgamesh)
Hi:
I'm trying to control a servomotor HS-645MG with the Altera FPGA DE0
using VHDL. According to my limited knowledge (and according to other
programmers) these are the code for frequency dividing and pwm:
Frequency divider:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity clk64kHz is
    Port (
        clk    : in  STD_LOGIC;
        reset  : in  STD_LOGIC;
        clk_out: out STD_LOGIC
end clk64kHz;
architecture Behavioral of clk64kHz is
    signal temporal: STD_LOGIC;
    signal counter : integer range 0 to 4999 := 0;
begin
    freq_divider: process (reset, clk) begin
        if (reset = '1') then
            temporal <= '0';
            counter  <= 0;
        elsif rising_edge(clk) then
            if (counter = 4999) then
                temporal <= NOT(temporal);
                counter  <= 0;
            else
                counter <= counter + 1;
            end if;
        end if;
    end process;
    clk_out <= temporal;
end Behavioral;
PWM
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_unsigned.all;
entity pwm is
  port(
    clr : in std_logic;
    clk : in std_logic;
    duty : in std_logic_vector (7 downto 0);
    period : in std_logic_vector (7 downto 0);
    pwm : out std_logic
end pwm;
architecture pwm of pwm is
signal count : std_logic_vector(7 downto 0);
begin
  cnt: process(clk, clr) -- 4 bit counter
  begin
    if clr = '1' then
      count <= "00000000";
    elsif clk'event and clk = '1' then
      if count = period -1 then
      else
        count <= count +1;
      end if;
    end if;
  end process cnt;
  pwmout: process(count, duty)
  begin
    if count < duty then
      pwm <= '1';
    else
      pwm <= '0';
    end if;
  end process pwmout;
end pwm;
Top-design code
library IEEE;
entity pwm_top is
  port(
    clr : in std_logic;
    clk : in std_logic;
    pwm : out std_logic
end pwm_top;
architecture pwm_top of pwm_top is
signal new_clock : std_logic;
begin
clk_div: entity work.clk64kHz
    port map(
      clk => clk, reset => '0', clk_out => new_clock);
Pulse: entity work.pwm
    port map(
      clr => clr, clk => new_clock, duty => duty, period => "11001000", pwm => pwm);
end pwm_top;
Described with my own words, the frequency is divided by a 5000 factor
which yields to a new frequency of 10000Hz (0.1ms). Then the period of
the pwm is assigned as 200 so the frequency of pwm will be 20ms and the
duty cycle will be controlled with the DE0 built-in switches.
Unfortunately this doesnt work very well when the servo is connected,
for example, if the duty cycle is 0.5ms the servo is supposed to moved
to one end but instead, it seems to take a 45º position. For every other
position, the servo also moves but it doesnt move accordingly to the
duty cycle.
I have tested the servo with an arduino uno and works wonders.
What could be the problem?
Any ideas are welcomed.
What does the simulation tell you? Do you get what you expect?
What output level do you have? What level does the servo need?
Soko Loko wrote:
> clk64kHz
This ist NOT the way Clocks are generated in FPGA. Use the ONE and ONLY
50MHz clock in the entire design and use clock enable signals for all
slower counters.
Have a look at the attached file. Its does almost the same like yours. I
made it for playing a little with such a servo: the 4 buttons change the
PWM...
Author: FPGA advisor (Guest)
did you figure out already if you PWM physical suits your application?
typically servo motor controls wor with PDM rather PWM in order to
overcome certain issues caused by non linear torque behaviour.
Author: Ankit Patel (Guest)
please share something useful for cyclon 3 to servo motor programming.
  • [vhdl]VHDL code[/vhdl]
