Forum: FPGA, VHDL & Verilog MEGAWIZARD PLUG IN
Author: Mark Jomari (imaroj)
is it possible to select what kind of adder will be used in megawizard
plug in, for example,, i want all of addition will be ripple carry.
Author: expert (Guest)
there is no ripple carry adder. this is just theory from the human view.
we're doing a research about comparative analysis of various edge
detection, one of the parameters is the speed, so the panel suggest that
we need to be specific of what architecture we will use in multiplier,
adder, etc. to make it fair with other algorithm.
Author: P. K. (pek)
From the Megawizzard, I think this is not possible. The Adder will
either be implemented using dedicated hardware (DSP block adder) or
using standard logic array blocks to match the described behaviour.
Usually, as long as you get the required speed you don't care about how
it's actually implemented. Maybe you'll find out how the DSP block
adder(s) are implemented if you dig deep enough (for sure, it is not a
ripple carry adder).
However, if you want a ripple carry adder, you have to describe/build it
by yourself with an entity forcing it to do so.
Author: ChristophZ (Guest)
An other way would be to opimize all the algorithms to max. speed,
deciding for every mathematical unit which architecture will give the
fastest result and compare in the end the transistor count (ASIC) or the
number of used resources (FPGA). Keep in mind that the best algorithm
for ASICs could be a different one than the best for FPGAs.
we try to implement these algorithms, sobel, prewitt, robert, canny,
laplacian of gaussian,.  is it possible to program edge detection
without using this megawizard???
Author: Duke Scarring (Guest)
Yes of course.
Just use plain VHDL or verilog...
Duke
@ duke? sir , are you sure? how about the timing ? is it become a
problem
Author: P. K. (pek)
Mark Jomari wrote:
> is it become a problem
Not if you define properly your timing constraints. (*.sdc file...)
  • [vhdl]VHDL code[/vhdl]
