Forum: FPGA, VHDL & Verilog Some basic fpga questions
Author: James Yunker (Company: Naval Undersea Warfare Center) (newport_j)
Let me ask some really basic questions here.
What is the difference between an fpga development board and just an
fpga board?
Also, since most of my code that I want to speed up has been ported to
64 bits years ago what is there if any difference between 32 bit abd 64
bit linux aspertains to an fpga?
I know these may seem elementary to some, but to someone who is very new
to fpgas they are not.
Any help appreciated.
Thanks in advance.
Respectfully,
Newport_j
Author: Grendel (Guest)
to 64 Bit:
This only matters for PROGRAMS that run on a processor inside the FPGA -
like Cortex-A9 Cores (32 Bit) in Zynq.
In the FPGA fabric for actual data processing, you can use ANY
resolution you want. Also 62 bits, or e.g. 144 bits if you need it. Just
a question of # of ressources you want to throw at the problem.
> and just an fpga board?
Development is - obviously - for development purposes.
Other Boards might be intended to go into customer products or be used
directly in a productive environment (such as a PCIe accelerator Card).
Author: Klaus Falser (Guest)
FPGAs are completely different to microprocessors, so speeding up an
algorithm by simply bringing the code to FPGA will not work.
A FPGA can implement a microprocessor which can than run Linux, but this
processor and Linux wll be much slower than a high end microprocessor,
An FPGA brings you only an advantage if implement part of the algorithm
in hardware.
An example would be a cryptographic operation:
Instead of having a sequence of xor and shift operations executed by the
processor you have a hardware unit, which is loaded with 1024 bit and
all the shifting, xor-ing is done in a few clock cylces by hardware.
But even in that case you have to ponder the overhead time needed to
laod the hardware unit.
  • [vhdl]VHDL code[/vhdl]
