Forum: FPGA, VHDL & Verilog capacitor in vhdl ?
von angelo (Guest)
Hi!
Is it possible to modelise a capacitor in vhdl without using vhdl-ams?
In order to analyse his effect on a system in simulation.
Thank you
von Lattice User (Guest)
You can't model an analog component in VHDL.
You can use AFTER to describe the delay a cap adds to your digital
signals.
With "pure" VHDL it is not possible to perform such simulations. Of
course you can make a model of a simple capacitor that may change a
signal or a frequency directly.
Which effect do you want to analyze at all? A capacitor alone does
nothing. It must have a resistor or an inductance with it to change
something...
von Strubi (Guest)
You could port a capacitor model to VHDL, but that would be very quirky.
And you don't need to, there are some tools that let you interface a
SPICE simulation with virtual hardware.
If you just want to simulate the analog behaviour of fast I/Os, you'd
rather go for the IBIS modelling approach. VHDL is only good at digital
stuff (I know this could cause arguments).
Greetings,
- Strubi
von user (Guest)
you can simulate the load/discharge characteristics of a capacitor.
When you have a RC-Element you can model it, but only on discrete points
of time. http://en.wikipedia.org/wiki/Capacitor
von J. S. (engineer)
Why not?
VHDL offers simulation with "fs" granularity. This is more than
sufficient for simulating the analog behavior of pretty complex
circuits. For convenience this should be done in REAL to get most
reasonable results and simulation time.
For synthesizable code, the simulation becomes more coarse. Depending
one the equation accuracy and eventual compensation of the issues caused
by discrete time steps, one can achieve sufficient results for up to a
10th of the system speed, for full pipelined calculations. usually one
can assume at least 1% of system speed taking into account the enough
oversampling head romm which is required for filter applications. Some
attention has to be payed in terms of error accumulation of course.
With my VA-Synthesizers, electronic circuits were modeled at 768kHz
sampling frequency with an average accuracy of more than 16 bits.
Usually there were no significant difference between VHDL-ModelSIM
results and pSPICE results when using the same equations (ideal
components). Regarding an industrial design, resonators were
successfully modeled with >100MHz and about 10Bits, using parallel
calculation techniques.
http://www.96khz.org/oldpages/vamodelling2.htm
If there is enough time and only non realtime simulation is demanded,
ModelSIM is sometimes even the better choice in comparison to MATLAB
because of the higher calculation speed.
von angelo (Guest)
Jürgen Schuhmacher wrote:
> Why not?
Yes I'm agree, my work is to design an analog model in vhdl using real.
The board I have to modelise is 90% analog. I thought vhdl can't help me
with capacitor or resistor but your answers make me change my mind.
I provide a part of the design I have to modelise in attachment, so you
may help me to understand the effect of the capacitor in the system.
Thank you
von t0B! (Guest)
Have you ever heared of "Switched-Capacitor-Circuits"? Probably that's
what you mean, when talking about of a simulation of an analog circuit
in vhdl, such things also called analog-FPGA.
http://en.wikipedia.org/wiki/Switched_capacitor
Keep in mind that Jürgen is very experienced with VHDL. How much time do
you have for this task?
As far as I see it is a sample&hold capacitor. Or depending on what
comes left a simple RC filter...
von angelo (Guest)
The global system takes part of an internship project, which end in
September but for this subsystem I would like to get over it in a few
days...
The left part is the analog output of a DAC
von experto (Guest)
if only the capacitor is of interest, a simple integrator /counter
design will do, i suppose.
von Martin (Guest)
Modelling  in  vhdl-ams   is a nghtmare.
Go for  verilog-ams.
Here is the capacitor model
module cap(vp, vn);
inout vp, vn;
electrical vp, vn;
parameter real c = 0;
   analog
      I(vp, vn) <+ ddt(c*V(vp, vn));
endmodule
An integrator was not the right thing here. Basically it is a
IIR-behaviour with saturation like this:
if clk then condenser_voltage <= condenser_voltage * (1-x) +
driving_voltage * x, where ratio X is obtained from the parameters C and
R.
von Mohammad M. (mohammadmother)
i want work with ISE , and my question is can i simulate the analog
circuit by use of schematic in ise?
That is not a question of schematic entry but related to the limits of
discrete timing and accuracy of the model (VHDL/VERILOG) you are going
to provide to the simulator.
Regarding ISE, there is an issue anyway: It has no analog view, so
Vivado or ModelSIM should be focussed.
