Forum: FPGA, VHDL & Verilog problem with sinulation in ISE (FPGA)
Author: Zakariya AL-Mazroo'Ee (Company: ACT) (zakariy)
hi there
I got a problem with simulation ........ I am doing a simulation for PN
code generator and I wrote the sketch for it
I will go for small explanation to make the problem clear
PN generator:
This component implements 7-bit PN code generator using three stages
Linear Feedback
Shift Register (LFSR).
The Two separate PN generator entities were implemented, one each for
two sources. The 3-bit initializer (seed) was set within the VHDL coding
itself in each entity. The PN generator for Source 1 is initialized with
(S2 S1 S0) = 111 and generates PN code 1110100 whereas the PN generator
for Source 2 is initialized with (S2 S1 S0) = 110 and generates PN
code1101001.
so I wrote the sketch
I create two inputs one is( CLOCK ) and the other is (INIT) and the
output is (PNCODE)
after that I enter the simulation windows
for CLOCK input I right click than select ( Force Clock ) than I give 1
for ( Leading edge value ) and 0 for Trailing edge value and 100 ns for
(period)
for INIT input I right click than select  ( Force Constant ) than I give
0 for ( Force to value )
the problem is the output (PNCODE) is still Undefined and it give no
thing even after running the simulation
please help ...... I attach the files and sketchs
if the problem not clear yet let me know
Author: fpgakuechle (Guest)
Thats not the way to start a simulation. Do not use force clock or force
sognal during simulation. Instead write a testbench which generates a
clock and a reset pulse. For example :
http://vhdlguru.blogspot.de/2010/09/example-4-bit-...
Best regards,
> Best regards,
oh really.... sorry I am still beginner :)
I will check it
I wrote this topic many where but non answer me
thanks a lot fpgakuechle
  • [vhdl]VHDL code[/vhdl]
