Forum: FPGA, VHDL & Verilog Operator <DIVIDE> must have constant operands or first operand must be power of 2
von meno (Guest)
when i tried to make division it gave me that error in implementation
how i can overcome that??
signal sum: integer range 0 to 255;
norm_dis <= 1000*sum/32768;
: Locked by Moderator
von Bitflüsterer (Guest)
Xilinx does not support real math for synthesis. A short search with
your prefered internet search engine should have shown that.
von lelo (Guest)
and it gave me the same error,but when i divide by 3
i hope some one help us
von meno (Guest)
yes y r right ,but how i can solve it?
You may implement - or rather describe - a divider on your own. Possibly
there is an description on the internet. Just give your search engine a
try.
A good starting point is also the Hamburg VHDL Archive.
I forgot: There is a IP-Generator for dividers in Xilinx, too. You may
use this either.
von Achim S. (Guest)
what is the datatype of norm_dis? If it would be integer, the solution
would be quite simple: Just calculate 1000*sum and ignore the lower 15
bits.
If it would be floating-point (i.e. real), then you have to accept that
actual hardware/development-software of FPGAs is not powerfull enough,
to implement this calculation right away. A good solution then might be
to use fixpoint-calculation instead of floating point calculation.
I.e. just replace the expression
   1000*sum/32768 by
   1000*sum
and "keep in mind", that you have shifted the position of the
"decimal-point" 15 positions to the left. (well: it's not a decimal
point shift of 15 decimal positions, we just shift 15 dual positions as
2^15=32768)
von meno (Guest)
thanks a lot ,but i use 1000 because if i divide without the result
would be float so i get ride of it by multiply by 1000
von meno (Guest)
yes norm_dis is integer
Well, that's not exaclty true. The integer division of 255/32768 does
not result in a floating point value. It results in the integer constant
0. The integer calculation of 1000*sum/32768 results in an integer in
the range 0..7 (cause 1000*255/32768 is 7 plus some remainder).
So if the integer result is what you are interested in: just take the
multiplication of 1000*sum (which is synthesizable, either by logic
elements of with a multiplier IP-core) and ignore the lowest 15 bits of
the result. Ignoring 15 lsbs is equivalent to an integer division by
32768.
Maybe you could simplify your calculation further: the multiplication
with 1000 is very close to the multiplication with 1024. And the
calculation
   1024*sum/32768
is nothing else but ignoring the lowest 5 bits of sum.
von meno (Guest)
thanks a lot all
This topic is locked and can not be replied to.
