Forum: FPGA, VHDL & Verilog error with if generate
Author: bob (Guest)
Hi all,
I got some errors when I try to compile the following code:
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
library peb_lib;
use peb_lib.all;
entity adc_simu is
  port(  CLK     : in  std_logic;
    MODE    : in real;
    OF_out  : out std_logic; -- OF pin
    D       : out std_logic_vector(13 downto 0)
end adc_simu;
architecture archi of adc_simu is
component adc
  generic (RefH, RefL: real;
     VDD: real);
  port(  Ain_pos : in real;
    Ain_neg : in  real;
    CLK     : in  std_logic;
    MODE    : in real;
end component;
component square_generator
  generic(LOW  : real;
    HIGH : real);
  port(wave: out real);
end component;
component triangle_generator
  generic(AMP: real;
    OFFSET: real;
    FREQ: real;
    PHASE :real);
end component;
component sinus_generator
  generic(AMP    : real;
    OFFSET : real;
    FREQ   : real;
    PHASE  : real);
  port(sinus: out real);
end component;
component sawtooth_generator
  generic(AMP: real;
    OFFSET: real;
    FREQ: real;
    PHASE : real);
  port(sawtooth: out real);
end component;
signal plus: real;
signal moins: real;
type waveform is (sinus, triangle, sawtooth, square);
signal wave_type: waveform := sinus;
begin
  TRI:if wave_type = triangle generate
              Vplus: triangle_generator
                     generic map (AMP => 1.0,
                                  OFFSET => 1.5,
                                  FREQ => 100000.0,
                                  PHASE => 0.0)
                     port map (plus);
               Vmoins: triangle_generator
                                  OFFSET => 1.5,
                                  FREQ => 100000.0,
                                  PHASE => 180.0)
                     port map (moins);
  end generate TRI;
  SQ:if wave_type = square generate
               Vplus: square_generator
                     generic map (LOW => 1.0,
                                  HIGH => 0.000122)
                     port map (plus);
               Vmoins: square_generator
                      generic map (LOW => 0.000122,
                                   HIGH => 0.000244)
                     port map (moins);
  end generate SQ;
  SIN: if wave_type = sinus generate
                Vplus: sinus_generator
                                   OFFSET => 1.5,
                                   FREQ => 10000000.0,
                                   PHASE => 0.0)
                      port map (plus);
                Vmoins: sinus_generator
                                   OFFSET => 1.5,
                                   FREQ => 10000000.0,
                                   PHASE => 180.0)
                       port map (moins);
  end generate SIN;
  SAW: if wave_type = sawtooth generate
                 Vplus: sawtooth_generator
                      generic map (AMP => 3.3,
                                   OFFSET => 1.65,
                                   FREQ => 10000000.0,
                                   PHASE => 0.0)
                      port map (plus);
                 Vmoins: sawtooth_generator
                                   OFFSET => 1.65,
                                   FREQ => 10000000.0,
                                   PHASE => 180.0)
                      port map (moins);
  end generate SAW;
  CAN: adc generic map (RefH => 1.0, RefL => -1.0, VDD => 3.3)
           port map (plus, moins, CLK, MODE, OF_out, D);
end archi;
Errors are:
../RTL/adc_simu.vhdl:
        TRI:            if wave_type = triangle generate
ncvhdl_p: *E,ILSGRD (../RTL/adc_simu.vhdl,92|18): illegal reference of a
signal (WAVE_TYPE) during static elaboration [12.3].
        SQ:             if wave_type = square generate
ncvhdl_p: *E,ILSGRD (../RTL/adc_simu.vhdl,102|17): illegal reference of
a signal (WAVE_TYPE) during static elaboration [12.3].
ncvhdl_p: *E,ILSGRD (../RTL/adc_simu.vhdl,112|18): illegal reference of
ncvhdl_p: *E,ILSGRD (../RTL/adc_simu.vhdl,122|18): illegal reference of
Can you tell me what is wrong in my code please!
Author: ChristophZ (Guest)
For the condition in your "if...generate" construct you have to use a
generic or a constant, because both are static values when you are doing
a synthesis or the simulator compiles your sources.
Read: "You are giving me a signal to decide what I should do, but a
signal is some thing dynamic and I have to do a static (permanent)
decision."
Author: bob (Guest)
Thanks for your answer!
So, if I understand right I have to remplace the type waveform by a
integer or generic type in the condition?
No. You don't have to replace the type. You can use any type and all the
types you created yourself.
You have to chance wave_type, you can't use a signal here. You have to
use a generic (defined in the entity) or in this case simply replace the
word "signal" with "constant".
You understood him wrong. I'm not sure if it works, but try this:
constant wave_type: waveform := sinus;
Or try a generic (but then you will have to define a package with your
data type and include that in your entity)...
Author: bob (Guest)
Yeah I was wrong. Lothar you're right, I have tested your idea before
your post and is giving me no error.
Thank you both of you!
  • [vhdl]VHDL code[/vhdl]
