Forum: Locked Topics radiobuttons issues
Author: John Mayer (215)
I am having some problems with pushbuttons on my board.
I have a Codepiece which should write increment a value and show it on
the LCD, when i press the button.
For some reason does this code only work for one button on my board.
When i change the input to another button, it starts at the state where
the button is high, and then goes back to low.
It increments the value once at the start, without the button being
pressed.
But it reacts correctly when i press the button.
code attached
: Moved by Admin
Author: matzetronics (Guest)
John Mayer wrote:
> I have a Codepiece
Unfortunately we don't have this code - and without it its impossible to
tell what goes wrong. Please post the code or attach it.
Code here
Buttonleft and buttonright increment the value when it's beeing pressed,
but buttondown is the problem. the value gets incremented once
eventhough the button hasn't been pressed.
switch(state)
      case 0:
        if(buttonright_pressed())        // -- right
          state= 1;
        if(buttondown_pressed())        // left
             state= 4;
        if(buttonleft_pressed())
          state = 5;
      break;
      case 1:
        if(!(buttonright_pressed()))
          buttom_timer = TIM_100_MSEC;
        state = 3;
      break;
      case 4:
        if(!(buttondown_pressed()))
           state = 2;
      break;
      case 5:
        if(!(buttonleft_pressed()))
           state = 6;
      break;
      case 2:
        if(!--buttom_timer)
          tx_cmd = 1;
          xQueueSend(Queue1,&tx_cmd,0);
          tx_cmd = 0;
          state = 0;
      break;
      case 3:
        if(!--buttom_timer)
            tx_cmd = 2;
          tx_cmd = 0;
            state = 0;
      break;
      case 6:
        if(!--buttom_timer)
             tx_cmd = 3;
             tx_cmd = 0;
            state = 0;
       break;
: Edited by User
Author: Andreas Schwarz (andreas) (Admin) Flattr this
Which microcontroller? Which board? Which LCD? Which compiler?
This topic is locked and can not be replied to.
