Forum: FPGA, VHDL & Verilog Poor RTL optimization
Author: Kurt English (Company: RPI) (khenglish)
So my Verilog file for an asynchronous bi-directional memory mostly
works, but it has some problems.
1.  The layout is EXTREMELY inefficient, which can be seen in the RTL
viewer.  There is a 3-input AND-gate at the enable of every memory bit.
This AND-gate has the same identical inputs for every memory bit.  Every
single one of these AND-gates could be eliminated since the memory
latches are never supposed to be disabled.  Fixing this would probably
cut FPGA usage by over 50%.
2. The READY signal is at times undefined.  It should never be
undefined.  How can I fix this?
3. I can't get else statements to work.  When trying to use them I
always get a memory initialization error when compiling.
Below is the Verilog.  In the screenshot I also have the timing diagram.
module sysmem (
A,
WR,
D,
READY
//input ports
input [15:0] A;
input WR;
//output ports
inout [7:0] D;
output READY;
//registers/wires
reg [7:0] Dout;
reg [7:0] memdat [0:255];
reg READY;
initial begin
  $readmemh("sysinit.txt", memdat);
end
assign D = (WR) ? Dout : 8'bz;
always @ (*)
  begin
    begin: rdyset
      if (memdat[A] == D)
        READY = 1'b1;
      if (memdat[A] != D)
        READY = 1'b0;
    end
    begin: memread
      if (WR)
        Dout = memdat[A];
    end
    begin: memwrite
      if (!WR)
        memdat[A] = D;
    end
  end
endmodule
: Edited by Moderator
Where?
> FPGA
Which one and what toolchain do you use?
> Fixing this would probably cut FPGA usage by over 50%.
You should use one of the synchronous ram blocks. That would be the most
efficient way to implement memory ON a FPGA.
Your cannot use your ram the way you did it in the timing diagram in
real life!
Enabling the write signal all over the time will cause spurious writes
to any memory register due to glitches in the adress lines. You must
have any kind of enable signal to tell your ram that now data and
adress are valid.
Just have a look at the data sheet of some discrete asynchronous rams.
BTW: Pls wrap your code in the code tags
   [c]
     your code
   [/c]
Fixed it.  Adding a buffer instead of directly accessing the memory got
rid of the hundreds of extra inferred latches.  READY was screwed up due
to the testing schematic trying to write to the D bus the same time the
memory was writing to it.
module sysmem (
A,
WR,
D,
READY
//input ports
input [15:0] A;
input WR;
//output ports
inout [7:0] D;
output READY;
//registers/wires
reg [7:0] Dout;
reg READY;
reg [7:0] membuf;
initial begin
end
always @ (A or D or WR)
  begin
  membuf = memdat[A];
    begin: rdyset
      if (membuf == D)
        READY = 1'b1;
      else if (membuf != D)
        READY = 1'b0;
      else
        READY = 1'b0;
    end
  end
always @ (A)
  begin
    begin: memread
      Dout = memdat[A];
    end
  end
always @ (posedge WR)
  begin
    begin: memwrite
      memdat[A] = D;
    end
  end
endmodule
Its slightly more complex.
This code implements latches (which is usually not a good idea or
practice):
always @ (*)
  begin
    begin: memwrite
      if (!WR)
        memdat[A] = D;
    end
  end
And the "new" code implements flipflops
  begin
    begin: memwrite
      memdat[A] = D;
    end
  end
But keep in mind: you added one clock domain to your design. This may be
not reproducable sync to your master clock!
Yeah I'm not sure how the CPU handles WR timing or when it checks the
READY flag yet.  Definitely going to have to look it up and make sure
what I did works.  I don't think the READY flag is still quite right,
but it may be good enough to work.  Since I have to write the CPU
microcode I'll figure it out then :)
Also to answer your earlier questions this is on an old Cyclone II FPGA.
I cannot use the memory tool in Quartus because it does not work for
asynchronous memory on the Cyclone 2, while memory implemented directly
in VHDL or Verilog works fine.  The other big reason is because the
Verilog needs to be portable so that another group member can place and
route in Cadence to simulate a fab'd chip (simulating an 8080, possibly
a Z80 for a final course project).
Thanks for your help!
So it turns out that despite having a better looking RTL the memory is
still using an exorbitant amount of FPGA area.  I made another memory
that's simpler (not writable) but is 7 times larger (56bit word size)
and it takes 1/8th the FPGA logic.
module sysmem (
A,
WR,
D,
READY
//input ports
input [7:0] A;
input WR;
//output ports
inout [7:0] D;
output READY;
//registers/wires
reg [7:0] Dout;
reg [7:0] memdat [0:127];
reg READY;
reg [7:0] membuf;
initial begin
end
always @ (*)
  begin
  membuf = memdat[A];
    begin: rdyset
      if (membuf == D)
        READY = 1'b1;
      else
        READY = 1'b0;
    end
  end
always @ (A)
  begin
    begin: memread
      Dout = memdat[A];
    end
  end
  begin
    begin: memwrite
      memdat[A] = D;
    end
  end
endmodule
I shrank the memory size so it would compile faster.  Also for some
reason this is compiling into a dual port memory.  Not sure why.  A
screenshot of the RTL is attached.
If you know how to make the memory take less area I'd like to hear it.
  • [vhdl]VHDL code[/vhdl]
