Forum: FPGA, VHDL & Verilog read data from file
Author: Abdallah      (Company: Home) (my_name)
peace !
please! I'm coding for image processing, what I nead is read
data(integer) from file (txt,xml or dat) to implemente the code in the
board, the file is generated from matlab
Q1- what type of file should I use
Q2- does the txt file solve the problem( for simulation it's ok but the
question is for the implementation)
Q3- could you advice me for some books or links
Thank you very much....peace
Abdallah      wrote:
> what I nead is read data(integer) from file (txt,xml or dat) to
> implemente the code in the board
Did I get this right: you want to read from a file on a FPGA hardware?
On what kind of media do you want to access this file? USB? SD card?
CompactFlash?
: Edited by Moderator
yes, that's exacty what should I do ;in fact I have to read data from
file ( data are values of image pixel, this file is generated from code
MATLAB) and then I will test these values to other values already known.
by the way the code is included in preject of palm hand recognition, so
any advices or suggestion would be greatly appreciated .
> CompactFlash?
from USB
thanks for your response...peace
: Edited by User
>> CompactFlash?
> from USB
Then you will have to implement a USB Host Controller on your FPGA.
After that you will need a Mass Storage Device driver to access some
kind of File Sytem. All in all this is an extremely demanding task to be
solved when you want to do that all completely with a HDL like Verilog
or VHDL.
One way can be to use some softcore CPU and do only the signal
processing in real hardware...
And why do you need to read data from a file in realtime here?
I'm not sure about what your actual problem is...  :-/
because I'm building an embedded system for security access based on
palm hand, to open the door for those who the system recognize them.
the problem is: do the board accept reading from .txt file??
far as I know is .txt file used only for simulation, I want to confirm
the information
Author: Marius S. (lupin)
If you use the VHDL file operators (std.textio etc) then it's just for
simulation.
To read a file for synthesis you have to design some interface to some
kind of memory and read the file from the memory.
> simulation.
that's right, I used std.textio but I want for synthesis, thatks for the
advice
I'm obliged to use the RAM, as I know it needs an Interface or some
think like that..... Could you please guide me to some reference and
index some keywords  that I need to make this project.
  • [vhdl]VHDL code[/vhdl]
