Forum: FPGA, VHDL & Verilog GTP Transciever
Author: Alexander Lutovid (lutovid)
Hi all.
I have a problem with clock correction(CC) in GTP
Transciever(transmitting data between two FPGA's). I have two bytes
interface without 8b/10b coding.
For example i always send X"5555" and set clock correction sequence as 1
byte X"55" in wizard. But RXCLKCORCNT always "000".
But when i set "Don't care" on CC seq - CC work correctly!
I'v tried X"AA" CC sequence - it does not work too, so i have RX buffer
underflow sometimes.
As I understand, I have wrongly specified CC sequence, but i can't
understand where i have mistaken.
Author: Duke Scarring (Guest)
In simulation or in hardware?
In hardware between 2 FPGA's.
In simulation i haven't detect this problem;
When i connect RX to TX(physically) on one board it also works
correctly.(Because it does not need CC)
: Edited by User
It works)
When i set RX_DECODE_SEQ_MATCH_0 False
But i have one question: If i use 16 bit interface how i can use 8
bit(or 16) CC sequence( CLK_COR_SEQ_1_1_0 - 10 bit)? otherwise byte
alignment will be lost(my block, using RXSLIDE)
: Edited by User
  • [vhdl]VHDL code[/vhdl]
