Forum: FPGA, VHDL & Verilog Logic question
Author: Sudhakar Pall (Company: Oracle) (dhakster)
Hello Verilog Experts,
    I am looking to optimize my code in terms of gates/logic. Please
suggest.
I have a 64 bit wide 512 elements array
 module A;
   reg [63:0] data [511:0]
 endmodule
   Each data array element is mapped to a signal internal to the design.
   Now, I need to send ONLY the array elements that changed in current
clock cycle through to some external pins.
   Think of it all in FPGA Hardware.
   To detect which element changed, I could copy the whole arrray into
some local 64 bit 512 array in previous clock cycle, xor with the
current clock array element etc... but this would eat up a lot of
register space, increase step count and all ... Is there a better way to
identify which of the array elements changed in current clock cycle
(compared to the previous). Thanks.
  PS: I am interested in every array element but not in each bit.
Sudhakar Pall wrote:
> Is there a better way to identify which of the array elements changed
> in current clock cycle (compared to the previous).
If you get the data in parallel and you want to do all of the compare
procedure in one clock cycle, then it will need at least 64*512 =
32768 flipflops. Theres no chance to escape.
But if you get the data via a serial interface you could compare it in
small amounts step by step.
So the questions are: WHERE does this data come from? WHERE does it go
to? WHAT data rates do you need?
Data is in parallel and goes out through external pins.
FPGA connected to a target interface, design is on the FPGA (includes
this module as well) and I would like to minimize the data going out
through to the target connected.
I am ignorant to the data rates for now since much of it depends on
target interface connected.
Here is what I was thinking, please let me know if you think of better
ways,
Prototype:
   reg [63:0] prev_clock_data[511:0]
   reg transition [511:0]
   transition [i] = | (prev_clock_data.. ^ data.. )
   for loop ...
     if (transition [i] )
        external_interface = data [i];
I am trying to look and see if I could optimize the number of registers
used here. How to store previous clock data running by the same clock on
FPGA is another thing, suggestions would help me here too. Thanks.
> Data is in parallel
512 pins for data input, really?
> for loop ...
Did you know: each loop in Verilog/VHDL is unrolled to real parallel
hardware.
>> Data is in parallel
Data bus included module is within the FPGA. No external /IO.
>> for loop ...
> hardware.
I am missing your point here. Can you elaborate ?
>>> Data is in parallel
>>> for loop ...
>> hardware.
I mean I understand the fact how hardware / FPGA handles the logic, but
don't quite get where you are heading with this.
So: where does the data come from?
> but don't quite get where you are heading
If the data is generated one data line after the other, then it is not
necessary to compare the whole array every clock cycle. Instead it
would be enough to compare only line...
Author: Uwe (Guest)
Perhaps you can put a 64-Bit Comparator between the Signal Source and
the Data lines of RAM-block where the Signal will be stored. When the
Comparator has detected a difference the FPGA should save the address
lines of that RAM Cell or set a '1' in an 510Bit Array that represent
the Position of the Difference.
With the description above no RAM will be invoked. The design also will
not be mapped into LUTs, insted each of the 32768 memory bits will eat
up one flipflop.
Author: Uwe (Guest)
oh, I missed it ...
Design is synthesized on FPGA's. There are 64 bit signals from the core
logic that are assigned to data array elements. Probably I could have
data as wire, use local_data to store up for previous clock cycles
data and then perform xor operation on both to detect the transition.
This atleast makes things a bit more clear, thanks for asking the
question.
But I will have to save previous data into register ... so that many
flops. I guess that cannot avoided.
But as far as I see previous Data is only 64 bits wide. Thats much less
than 32768...
  • [vhdl]VHDL code[/vhdl]
