Forum: FPGA, VHDL & Verilog Need help with VHDL reading from file
Author: Darren Seow (Company: STP) (lift)
Hi guys,requesting some help with my vhdl code,i am writing a Data
Encryption Standard using VHDL.I have a problem with reading from a
file.I can write to a file if I entered the inputs manually in my
testbench but I cant write to a file when I try to read the inputs from
a file.Below is a portion of my code and the input/output files.Any help
would be greatly appreciated and thanks for your time!
Input File(.txt)
_________________
785AC3A4BD0FE12D
123456789ABCDEF0
785AC3A4BD0FE12D
Output File(.txt)
_________________
1335 ns FD9CBA5D26331F38
2135 ns 17EA4A8B48C14DA0
2935 ns FD9CBA5D26331F38
Code(data_in<=input,data_out<=output)
____________________________________________
-- data_in <= x"785AC3A4BD0FE12D",
-- x"123456789ABCDEF0" after 1400 ns,
-- x"785AC3A4BD0FE12D" after 2200 ns;
process
use std.textio.all;
use ieee.numeric_std.all;
file inputfile:text open read_mode is "input.txt";
variable ipa:std_logic_vector(63 downto 0);
variable inline:line;
begin
 while not(endfile(inputfile))loop
  readline(inputfile,inline);
  read(inline,ipa);
  data_in<=ipa;
  wait for 4000 ns;
 end loop;
 wait;
end process;
 function_select <= '1';
 --'0' after 2100 ns,
 --'1' after 4550 ns,
 --'0' after 5800 ns;
 tb: PROCESS
 BEGIN
  key <= x"38A84FF898B90B8F";
  wait for 1400 ns;
 end process;
 process
  use std.textio.all;
  file resultfile:text open write_mode is "result.txt";
  variable outline:line;
 begin
  wait on data_out;
  wait for 50 ns;
  write(outline,now,right, 2);
  hwrite(outline,data_out,right, 40);
  writeline(resultfile,outline);
 end process;
end key;
: Edited by Moderator
Darren Seow wrote:
> but I cant write to a file when I try to read the inputs from a file.
Why not? What error message do you get?
Hi there,sorry for the late reply,issue has been solved.I forgotten to
add a "h"in front of read.Hence,it wasnt able to read hexadecimal
inputs.Thanks for your time!
  • [vhdl]VHDL code[/vhdl]
