Forum: FPGA, VHDL & Verilog VHDL Code works, need help with testbench and isim
Author: Tai Tai (john9686)
Hi!
I'm working on this function. I need some help. Here is my code. It
works sythesizes and implements the design. When I create a testbench
using xilink I get the code attached. I add binary value "222" to
switches in testbench. When I run isim I get the attached image. Whats
wrong???
T = Min[Max(A,512),B]xC
CODE:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity functionT is
    port(
        clk: in std_logic;
        switches: in std_logic_vector(9 downto 0);
        output: out std_logic_vector(9 downto 0)
end functionT;
architecture ARCH of functionT is
--signals
signal A: unsigned(9 downto 0):=("0110101001"); -- A=425
signal B: unsigned(9 downto 0);
signal sig512: unsigned(9 downto 0):=("1000000000"); --sign512=512
signal T: unsigned(9 downto 0);
signal x, y, z: unsigned(9 downto 0);
begin
    B <= unsigned(switches); --something like that
    x <= A when A>sig512 else sig512;
    y <= x when x<B else B;
    z <= y * 3;
    T <= z(7 downto 0) & "00";
    output <= std_logic_vector(T);
end ARCH;
: Edited by Moderator
> testbench_code.txt
None of my VHDL files end up with ".txt"
Why does yours?
Because signal A is not in a register, it cannot store the assigned
default value. So one timestep after the first initialisation the signal
A will become "UUUUUU...". This results in the reported metavalue. Try
it this way:
> constant A: unsigned(9 downto 0):=("0110101001"); -- A=425
just copy pasted the testbench.vhd to notepad. here is orginal
testbench.vhd.
does not work. Is the error coming from my testbench code?
In the image attached the clock is default 0
Author: Duke Scarring (Guest)
Tai Tai wrote:
> does not work.
You provocate a type mismatch (std_logic_vector vs. unsigned).
With these changes it will work:
33c33
< --USE ieee.numeric_std.ALL;
53c53
<    signal switches : std_logic_vector(9 downto 0) :=("0011011110"); --A=222;
>    signal switches : unsigned(9 downto 0) := to_unsigned( 222, 10);
66c66
<           switches => switches,
>           switches => std_logic_vector( switches),
Duke
  • [vhdl]VHDL code[/vhdl]
