Forum: DSP Use of Fatfs on a TMS320F28335
Author: koko (Guest)
I have a little problem with the use of Fatfs on my DSP. In fact,
opening a file on a microSD doesn't work...:(
Smple code:
//...Variable initializations...
// Mount return FR_OK
f_mount(&FatFs, "0:", 0);
// Opening fails...
f_open(&File, "Tes.txt", FA_OPEN_EXISTING | FA_READ);
// It returns FR_NOT_READY because it the disk_initialize function
// dosn't work and satisfy the condition STA_NO_INT which return
//FR_NOT_READY...
So, I have no more idea where I could search. The micro_SD is a Kingston
(4GB) class 10 which is inserted in a SD adaptater which is linked to
the DSP. On my computer or mobile phones everything is OK on the card,
so it's not the health of the card but what ? What can do this kind of
error ?
The clock speeed of SPI is 300kHz so it's not really great to cause
issue...
I give you the diskio.c file which is the only one I change to adapt on
my target. If somebody could understand something and know the FatFs
module, I really thank him/her to help me to understand...
Author: Andreas Schwarz (andreas) (Admin) Flattr this
koko wrote:
> Mount return FR_OK
f_mount does not actually communicate with the card, so this doesn't
help ypi.
Did you set up your SPI interface correctly? Do the SPI read commands
return something sensible? One of the most common errors is to set the
clock phase and polarity incorrectly, so double check if yours is set
correctly; try out all possibilities if necessary. If that doesn't solve
the problem, try a different card.
: Edited by Admin
Author: joe vast (Guest)
The problem is size of char, which is 16 bits for TMS320F28x. So, the
comparisons that include an unsigned char variable and a hex constant
will fail. For the disk_initialize function, it fails when wait_ready
function is called, since variable res never becomes equal to 0xFF.
BYTE wait_ready (void)
    BYTE res;
    Timer2 = 50;    /* Wait for ready in timeout of 500ms */
    rcvr_spi();
    do
        res = rcvr_spi();
    while ((res != 0xFF) && Timer2); // <--- res != 0xFF fails
    return res;
In order to access single byte value, __byte intrinsic function can be
used as the following:
__byte(&res,0) != 0xFF
Author: matzetronics (Guest)
> (4GB)
In this case make sure you have followed the guidelines for FatFS
regarding High-Capacity SD Cards. Everything above 2GB today will be
SDHC instead of the older SD:
http://elm-chan.org/docs/mmc/mmc_e.html
Oops, sory i didn't see that this is a very old posting. Sorry for
eating up memory in the database.
