Forum: µC & Digital Electronics basic knowledge - processor
Author: michael (Guest)
hi
example:
if i start a main function with a var A = 0 and let it add one every
cycle:
main(){
int A = 0;
A++;
@ atmega 8 with 3.6mhz is 2.7 *10^-7 sec.
when there is no interrupt and i stop after eg. 10 cycles, is there
A=10??
Author: Andreas Schwarz (andreas) (Admin) Flattr this
First of all, unless A is declared volatile
(http://en.wikipedia.org/wiki/Volatile_variable), the compiler will
probably remove your code altogether, since it has no effect.
Assuming you meant
while(1) { A++; }
you won't get one increment per cycle, because the increment and jump
instruction together take more than one cycle.
: Edited by Admin
yeah thats exactly what i wanna know.
does every command use one cycle?
Author: 6A66 (Guest)
Hello Michael,
you wanna look up the assembler listing of your code to find out what
the compiler generated. After that you wanna look up the datasheet of
the prcessor to find out how many (machine-) cycles each instruction
requires, including the loop back. That gives you a exact numer of clock
cycles required and therefore the exact time required for execution.
rgds
Author: Rene H. (Guest)
Hi Michael,
to be sure, you have to disassemble your compiled code, cause there are
many assembler instructions which needs more than one cycle e.g. RET
needs 5 cycles (just take a look at the data sheet, Chapter "Instruction
Summary").
Regards,
René
