Forum: FPGA, VHDL & Verilog Help TO DISPLAY 2 LINE MSG USING SPARTAN 3AN
Author: ayna cancerian (Company: student) (cancerian)
Hi i need help to display 2 line message on spartan 3an LCD !1 anyone
have any idea please help
thanks
Author: Martin Schwaikert (sirnails)
Show us, what you got so far.
Author: Holger (Guest)
Please Check first this for the LDC Pin_ -Out. via Spartan 3E Board .
http://www.xilinx.com/support/documentation/boards...
So you need to get the source code for LCD via FPGA ...
Good Luck.
http://www.cosmiac.org/pdfs/09Tutorial6.pdf
This is the hint for source code via FPGA to LCD.
May other users help to get the source code.
But first you must know the SPARTAN 3E PIN-Out via FPGA<-->LCD.
see (UCF) File..
Do you use VHDL or Verilog? .
May other find the ORGINAL SPRARTAN 3E Stock Firmware Reference File for
the Project on Spartan 3E Board.
Greetings Holger.
Here is a Video that shows how LCD via FPGA works .
And you can watch the part of the source code.
Youtube-Video "LCD Spartan 3E"
I will look for the orginal SPRATAN 3E source code and Project File,
wich is on the Board when its delivered.
Can anyone find it ?
Greetings Holger.
Author: Holger Harten (holger-h-hennef)
Program LCD on Spartan-3E, Verilog/FPGA (TestLCD)
Trap:
Please notice exact the sfr_bit set fixed to 1 to disable the Stata
FLASH
Device wich is also part of the´shared BUS via LCD.
See code review , see FPGA OUTPUT-PORT SFR == 1.
Link:
 Youtube-Video "Program LCD on Spartan-3E, Verilog/FPGA (TestLCD)"
Greetings Holger.
: Edited by User
i am using Spratan 3an board using VHDL !! i made code but its not
working
Can you put the orginal Stock Software thats delivered with Board
as bitfile on,
that you can see if the LCD Hardware is working anyway ?
Trap:
adjust contrast through trim pot.
(may you Trim-Pot is not ok)
How to Interface 2x16 LCD with Spartan-3an FPGA
Link:
http://www.pantechsolutions.net/cpld-fpga-boards/2...
check the Pinning there.  See map
There is the VHDL Code you can download after registration.
Greetings Holger.
> working
Can you write a Test-Bench to Simulate it on eg.
ModelSim  Simulator?.
Here is the code for VHDL
-- Description:    16x2 Text LCD controller for 8bit Mode
--                 used on the Spartan-3A Starter development board
http://www.mikrocontroller.net/attachment/highlight/49310
But keep the special Pin at the Strata Flash at permanent High.
It is shared with the LCD Bus.
Greetings Holger.
  • [vhdl]VHDL code[/vhdl]
