How to combine I²C/TWI, SPI and UART on one connector?
OP #3353564
Hello!
I²C (aka SMBus/TWI), SPI and TTL-UART are widely used for robotics and
model-building (RC Helicopter, Lego, ...)
I want to use the same connector-type for all of these three protocols
alternatively.
Lego Mindstorms combines SCL/RXD on one pin alternatively, and SDA/TXD
on the other.
In contrast at the ATtiny1634 SDA, RXD and MOSI are on the same pin.
I want to be compatible as much as possible.
Do you know other examples? Which signals should I combine on the same
pin?
BTW: I know the electrical issues (OC/pullup/tristate), that's not my
question.
Torsten
Guest #3353823
Combining different busses into the same wires, has the effect, that
only one of these can be used on the whole project.
So why different busses at all ???
Guest #3353837
I2C on a device, which expect UART cause rubbish.
UART on a device, which expect I2C cause rubbish too.
SPI on a device, ...
It's fundamental, that all devices on the same bus speak the same
language.
OP #3353849
tellme wrote:
> why do you want this?
I want to reduce the amount of necessary adapters for my different
embedded projects. Sensors and actors should be interchangeable.
PS: Please don't think, I want to combinine different busses into the
same wires.
tellme wrote:
> Tell us about your use-case(s).
The use-case: Different peripherals (sensors, actors, ...) with
different protocols (USB, TWI, SPI and UART) on the same connector.
It's nearly the same as with Lego NXT and EV3 or with the FSA9280A in
mobiles.
My problem: There is no standard. I hope, there is a commonly used
assignment. But up to now I only know 2 examples: ATtiny1634 and Lego
EV3. And these two examples are exactly vice versa. :-(
I tend to be compatible to Lego EV3 and FSA9280A:
SCL = RXD = USB-DP
SDA = TXD = USB-DM = MOSI
I²C-SCL can be SPI-MISO or SPI-SCLK ?!
Guest #3353852
Then the connector must be wide enough to carry separate pins for each
bus.
OP #3353862
You need separate pins for each bus, but not for different protocols on
different busses.
So, that's not the quetion. I want to use one of those protocols
alternatively with the same pins, as I said. ^^
Do you know Lego EV3 Sensors and mobiles with FSA9280A? They have no
separate pins.
Do you know other examples with SPI and TWI?
PS: I wrote:
> Different peripherals on the same connector.
Sorry, I meant on different connectors with the same pinout. The
headline should be:
How to combine I²C/TWI, SPI, UART and USB in one pinout?
Guest #3353884
> separate pins.
As I said, then you can only use one bus on a project.
To communicate with I2C slaves you must first disconnect all UART slaves
and vice versa.
The master (Lego EV3) can change its configuration at run time, but it
can't be done by a slave. The slave was always only I2C or only UART.
OP #3353902
peda wrote:
> As I said.
We both said or meant the same. ;-)
One example:
I 've a 8-ch remote switch for 230V mains that understands all mentioned
protocols. It may be selectable by DIP-SW or auto-detect.
I want to connect it
- to Lego NXT via I²C,
- to Lego EV3 via UART,
- to my fish tank (aquarium controller) via SPI and
- to my PC via USB.
And all that without the need of crossing wires.
Technical this is "no problem". I'm uncertain about the signal-mapping
(pinout), because it sould be as compatible as possible.
So: Do you know other examples with SPI and TWI?
Perhaps it's typical German: Everything has to be standardized. ;-)
Guest #3354044
Come on guys, the question is not so hard to understand. The advantage
he is going to gain is that he can always use the same cables and buy
connectors in higher volumes.
Alternatively means: either one or the other!!
To answer your question:
I would not take the AVR as a reference. Take any other microcontroller
and you will see that they combine different pins. - It depends on the
silicon inside...
I would do it this way:
1       2       3       4
SCLK  MOSI  MISO  SCS  [SPI]
-       TX      RX      -    [UART]
SCL     SDA or  SDA     -    [I2C]
[clock] [out*]   [in*]
*out and in are refering to the controller.
I think it is also very handy to add some power pins to your 'standard',
e.g. 3V3, 5V, 12V or so.
Best,
braintu
OP #3355537
@braintu + Patrick: Many thanks + vielen Dank. :-)
> 1   2   3   4 …
First, I had the same thought. I meditated long on the connector
technology. After all, I choose 5-Pin Mini-USB, although SPI with 3
wires may be a problem.
I choose Mini-USB, because the connectors are very cheap (few cents on
aliexpress) and receptables are available as SMT and THT.
Or do you think, another connector would be better?
Bidirectional SPI is also possible, if master and slave know, when to
change the direction.
Attached my proposal "UniversalConnector.png".
Lego-RJ12 is used for Lego mindstorms sensors, EV3 and NXP. I'll build
some adapter.
● 1,8..5,5V: Power from master to slave
● VDD: CPU-Voltage from slave to master (for level-shifter if necessary)
● Data?: Data-Wire for 1Wire-Slaves: I'm uncertain about the pin
Any comments? Or is it a good idea?
OP #3355708
Sorry, I confound the RS-485 pins (A=+ / B=-).
Lego NXT also supports RS 485:
http://ev3-wissen.engeln.info/doku.php?id=pin-belegung_der_nxt_western-stecker_kabel
An alternative with bigger connectors (not for RC Helicopter) is RJ45.
The benefits compared to 5-Pin Mini-USB are:
● There are cheap and ready to use Ethernet patch cables available.
● You have more wires, e.g. for bidirectional SPI
● You can group into "in", "out" and "clock", like braintu ^^
But using these cables means, you have to be aware of the twisted pairs,
if you assign the signals to the pins.
I found many examples for RS-485 on RJ45, which didn't fit to the
twisted pairs of Ethernet patch cables.
A good suggestion was on doityourselfchristmas.com, but you could also
be geared to the standard "POE DC on spares".
For an "universal RJ45 connector", the signals for the other protocols
have to be assigned. My idea is attached in the picture.
One Problem: I need different adapter for Lego I²C and Lego UART.
A question of your own? This thread is over 13 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
