Forum: FPGA, VHDL & Verilog Control shift registers with FPGA
von Joserra (Guest)
Hi all, I am new here. I tell you my problem. I have been now several
days trying to figure it out how to control shift registers SIPO 74LS164
with my FPGA. I am doing a clock, displaying hours, minutes and seconds
with NIXIE tubes. What I need to do is to send each second, 24 bits, and
remain those 24 bits displaying in the NIXIE tubes during the second,
till the new second comes and new 24 bits are sent. Maybe this is a
stupid question but I don't know how to produce my clock signal and my
serial output to control this ICs.
I already have a vector of 24 bits and the schematic of how cascading
these ICs so that's not the problem. I think you get which my problem
is.
Please if somebody can help me would be so so great!
Thank you very much
Regards
von FPGA-Takt (Guest)
what HDL do you use?
In Verilog I would try something like this (prob. with errors and not a
good style)
module( start, stop, secminhour, clk, clkout, dataout);
input start, secminhour, clk;
output dataout, clkout;
reg stop = 1'b1;
reg[0:3] cnt = 4'b0000;
wire[0:23] secminhour = 24'b0;
wire start;
wire clk;
wire clkout;
wire dataout;
assign dataout = secminhour[cnt];
assign clkout = (stop == 1'b0) ? clk : 0;
always @(posedge clk) begin
  if (start = 1'b0) begin
    cnt <= 4'b0000;
    stop <= 1'b0;
  end else begin
    cnt <= cnt + 1;
    if (cnt >= 23) begin
      cnt <= 4'b0000;
      stop <= 1'b1;
    end
  end
30
31
end
32
33
endmodule
U also need a StateMachine to controll this, something like generate
Data, set start from low to high, wait till stop is set (and the Data
output was generated) and set start low.
von Joserra (Guest)
thank you for your answer, I use VHDL, have never used Verilog. I didn't
think about doing it with a StateMachine, maybe that solve my problem,
I'll focus the problem from this point of view.
Really, thank you.
Regards
Joserra wrote:
> I didn't think about doing it with a StateMachine, maybe that solve my
> problem
Just keep in mind: even every lousy little conter is a State Machine...
Joserra wrote:
> I don't know how to produce my clock signal and my serial output to
> control this ICs.
Its fairly easy, because no framing is needed for this shift registers.
So the only thing you must provide is a shift "clock" and stable data on
the rising edge of this clock...
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity SPI_Master is  -- SPI-Modus 0: CPOL=0, CPHA=0
    Port ( TX_Data  : in  STD_LOGIC_VECTOR (Length-1 downto 0); -- Sendedaten
           MOSI      : out STD_LOGIC;
           SCLK      : out STD_LOGIC;
           TX_Start  : in  STD_LOGIC;
           TX_Active : out STD_LOGIC;
           clk       : in  STD_LOGIC
end SPI_Master;
architecture Behavioral of SPI_Master is
  type   tx_states is (idle,txactive);
  signal txstate    : tx_states := idle;
  signal spiclk : std_logic;
  signal spiclklast: std_logic;
  signal bitcounter    : integer range 0 to Length; -- if bitcounter = Length --> all bits transmitted
  signal tx_reg        : std_logic_vector(Length-1 downto 0) := (others=>'0');
begin
  ------ management FSM --------
  process begin
     wait until rising_edge(CLK);
30
     spiclklast <= spiclk;
31
     case txstate is
32
       when idle =>
33
             TX_Active   <= '0';
34
             bitcounter  <= Length;
35
             sclk      <= '0';
36
             if(TX_Start = '1') then
37
                stxstate <= txactive;
38
                TX_Active   <= '1';
39
             end if;
40
41
       when txactive =>  -- transmit tx_reg
42
             spiclk <= not spiclk;
43
             if (bitcounter=0) then -- all bits transmitted -> idle
44
                spiclk  <= '0';
45
                txstate <= idle;
46
             end if;
47
             if(spiclk='1') then
48
                bitcounter <= bitcounter-1;
49
             end if;
50
     end case;
51
  end process;
52
53
  ---- TX Shiftregister -------
54
  process begin
55
56
     if (spitxstate=idle) then  -- reload when idle
57
        tx_reg <= TX_Data;
58
     end if;
59
     if (spiclk='1' and  spiclklast='0') then -- rising_edge --> assign next data bit
60
        tx_reg <= tx_reg(tx_reg'left-1 downto 0) & tx_reg(0);
61
     end if;
62
  end process;
63
64
  SCLK    <= spiclk;
65
  MOSI    <= tx_reg(tx_reg'left);
66
67
end Behavioral;
(Based on the SPI-Master:
http://www.lothar-miller.de/s9y/categories/45-SPI-Master)
