Forum: FPGA, VHDL & Verilog Can i store 128X128 X 10 Images
Author: Abdullah K. (abdullah_k)
Hi Every one ,
I'm building and image processor , I want to store ten 128 X 128 images
in the Memory of a verilog code(i.e. Processor)
Can FPGA store this much amount in actual ? (any FPGA)
Regards
No, not any FPGA is able to, but some of them will be...
128x128 is 16K. So now you need 10 of it, this is 160K pixels. And now
the big question is: what is one pixel? Is it a black-white pixel with
one bit, or is it a true color with 24 bit width?
By multiplying the 160K with the pixel width you can calculate the
overall memory. And with this number you will easily find one of the
newer FPGAs fitting your requirements. Xilinx has FPGAs up to 68Mbits:
http://www.xilinx.com/products/silicon-devices/fpg...
Lattice has up to 6.8Mbits:
http://www.latticesemi.com/Products/FPGAandCPLD/La...
And so on...
Author: Uwe (Guest)
Author: Lars Large (Guest)
Typically ,an image sensor gives 10 - 16 bit per pixel, even color
sensors because of the Bayer
filter(http://en.wikipedia.org/wiki/Color_filter_array).
 24 bit per pixel from a sensor not realistic. In a computer the 24 bits
will be tored in 32 bit because of cpu architecture (there are 16 or 32
bit registers, not 24 bits).
Best regards,
Thanx Evry one for your reply
Let me ask it in another way
I have images sized 128 X 128
Bits per pixel are 8
need to store 10 images
total sized required will be 128 X 128 X 8 X 10 = 1310720
can is declare this much memory on any FPGA in the following way ?
considering all pixel in a row orientation
 Verilog :
                  reg [1:160000] mem[1:8];
 VHDL:
 type memory_array is  array (0 to 160000) of std_logic_vector(7 downto
0)
Of course you can declare it. But another question is whether this
discription can be implemented on "any" FPGA. So you must be more
specific about the FPGA supplier and device...
> VHDL:
Why the heck do you declare 160001 bytes?
You need exactly an array size of (0 to 128*128*10-1)!
Thanx alot Lothar Miller thats really a relief !
im not worried about the device because i have to simulate till
synthesize only , But there must exist a devise of such size .
Actually i have to store 10 images 128 X 128 (its 160k)  i have my own
memory manager to carter them as images.
I have another question dost the memory declaration (As above) uses
block memory of FPGA ?
Thank you for your support
: Edited by User
Look at your synthesizers user guide. If you describe the array the
correct way, a BlockRAM (or Embedded RAM or whatever your specific
FPGA incoorporates) will be synthesized.
  • [vhdl]VHDL code[/vhdl]
