Error (12007): Top-level design entity "components" is undefined
OP #3310692
• ▲ useful
▼ not useful
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
PACKAGE components IS
  -- 2-to-1 multiplexer
  COMPONENT mux2to1
    PORT (  w0, w1   : IN   STD_LOGIC ;
        s     : IN   STD_LOGIC ;
        f     : OUT   STD_LOGIC ) ;
  END COMPONENT ;
  -- D flip-flop with 2-to-1 multiplexer connected to D
  COMPONENT muxdff
    PORT (  D0, D1, Sel, Clock   : IN   STD_LOGIC ;
        Q       : OUT   STD_LOGIC ) ;
  END COMPONENT ;
  -- n-bit register with enable
  COMPONENT regne
    GENERIC ( N : INTEGER := 4 ) ;
    PORT (  R     : IN   STD_LOGIC_VECTOR(N-1 DOWNTO 0) ;
        Resetn   : IN   STD_LOGIC ;
        E, Clock   : IN   STD_LOGIC ;
        Q     : OUT   STD_LOGIC_VECTOR(N-1 DOWNTO 0) ) ;
  END COMPONENT ;
-- n-bit right-to-left shift register with parallel load and enable
  COMPONENT shiftlne
        L, E, w  : IN     STD_LOGIC ;
        Q     : BUFFER   STD_LOGIC_VECTOR(N-1 DOWNTO 0) ) ;
30
  END COMPONENT ;
31
32
  -- n-bit left-to-right shift register with parallel load and enable
33
  COMPONENT shiftrne
34
35
36
37
38
39
  END COMPONENT ;
40
-- up-counter that counts from 0 to modulus-1
41
  COMPONENT upcount
42
    GENERIC  ( modulus : INTEGER := 8 ) ;
43
    PORT  (   Resetn     : IN     STD_LOGIC ;
44
          Clock, E, L  : IN     STD_LOGIC ;
45
          R       : IN     INTEGER RANGE 0 TO modulus-1 ;
46
          Q       : BUFFER   INTEGER RANGE 0 TO modulus-1 ) ;
47
  END COMPONENT ;
48
49
  -- down-counter that counts from modulus-1 down to 0
50
  COMPONENT downcnt
51
52
    PORT (  Clock, E, L  : IN       STD_LOGIC ;
53
54
  END COMPONENT ;
55
56
END components ;
I just recently started to learn vhdl and I found this code online as I
was  researching on how to use components. When I try to run it, I get
that error.
how do i fix it
I have attached the source file too its on page 8, thanks for your help
in advance
#3312224
• ▲ useful
▼ not useful
What he is basically telling you is to create package out of modules. To
use a component you need not necessarily use a package. Just create a
module, for example, and call that in your other modules where you want
to use it (of course it should be added in your project).
See this for example:
http://www.cs.fredonia.edu/zubairi/training/vhdlcompo.html
and this:
http://www.doulos.com/knowhow/vhdl_designers_guide/components_and_port_maps/
Moderator (Company: Titel) #3313102
• ▲ useful
▼ not useful
Murali BN wrote:
> Just create a module, for example, and call that in your other modules
> where you want to use it (of course it should be added in your project).
VHDL is no programming language where you "call" a component!!!
VHDL is a hardware description language. Here you must have a "picture"
of a hardware inside your brain or on a sheet of paper (also called
schematic), and this picture can afterwards be described with VHDL. If
you cannot imagine what you are describing at the moment of typing, your
VHDL code will result in problems...
  • [vhdl]VHDL-Code[/vhdl]
