Forum: FPGA, VHDL & Verilog Controlling a linear CCD with FPGA
Author: Murat GUNES (Company: BEAM Ar-Ge) (mguneskou)
Hello everyone!
I am trying to make my own CCD controler board. For this aim I picked
Toshiba TCD1304 CCD detector, Terasic DE0 Nano board with Altera Cyclone
IV and FT2232H Mini Module from FTDI. The basic operation flow should be
like this:
1- Generate the three clock signals which are required by CCD (I have
done this)
2- Use the onboard ADC of DE0 Nano for to convert the data which comes
from the CCD (I have some problems in that point. I can use the ADC but
I am not sure about the data that comes from the CCD)
3- Write these data to the onboard SD Ram of DE0 Nano(Not yet)
4- Send these data to the computer using the FT2232H Mini Module(I have
experience about this).
At step two; I have no idea about the output signal of the CCD. I read
the manual of the CCD sensor and I couldn't undrstand how should I read
the data from it. Here is the link for the datasheet of the CCD:
http://www.eureca.de/datasheets/01.xx.xxxx/01.04.x...
If I can learn how the CCD gives me the data then I will be able to read
and write it to the board's RAM. And after that I already know how to
use the FT2232H Mini Module with DE0 Nano.
I use Quartus II and Verilog by the way.
Any suggestion, link or example would be greatly appriciated.
Thanks...
Author: Karl Könner (Guest)
Page 7 shows the output of the CCD:
For every shift cycle you get another signal at the output, which
relates the number of charges of the photo-cell. the leading and the
trailing charge-signal (marked as dummy) come from dummy cells, ie. do
not corrospond to a pixel, so you may ignore them. (well, sometimes this
pixel are used the generate a "black pixel reference level" but you will
need a specialized ADC to benefit from this).
 Shortly after shifting-out a single element you shall smaple it from
you ADC. So you can delaying the shift clock to generate the sample
clock.
One option could be to operate with an higher clock in fpga say 300 MHz
when the shift (pixel) clock is 50 MHz. then you have a counters runing
at 300 MHz, if the counter is counts 0,1,2 shift clock is high, and if
it counts 1,2,3 sample clock is High.  optimising the phase und pulse
width of ccd shift gain and sample clock reduce the pixel noise a lot.
OK this is just a sketch, often a look into a datasheet of  a line-ccd
controller (Keyword :"Linear CCD  Driver" ) or of a linear ccd optimised
ADC
i.e.
http://www.analog.com/static/imported-files/data_s...).
Best regards,
That fast? Slow down a little bit: the maximum master clock is 4MHz. And
SH ist not the "shift clock", because there is no shift clock at all.
With the SH pin you only control the shutter "opening"...
The process is to "clear" the ccd cells with a pulse on the ICG pin.
Then with each forth master clock cycle new analog data is output on OS
(so data rate is 1/4 the master clock).
page 2, table "pin names", line "SH"  -> reads "Shift gate"
Anyway, every charged coupled device needs a shift signal (sometetime
(internally, see block "Logic circuitry) generated by (internally)
overlapping clock signals) to move (shift) the charges over the "bucket
brigade". Shifting ist "essential" for CCD's, there is no CCD working
without a "shift-circuitry/clock). (See
http://en.wikipedia.org/wiki/Charge-coupled_device, search for the term
"shift" (Ctrl-f))
After "forcing and finishing" this shift by controlling the signals to
the CD-line,  you have to initiate the sampling of the analog output.
ACK
It's a bit confusing that there are 2 timing charts (p6/p7). At page 7
it seems that after every SH-Pulse new data is presented at the signal
output, where at page 6 there is just a single SH-Pulse.
I am more familiar with image sensor than with liniear sensors
Best regards,
Thanx you both for your urgent replies. I will check the things you
wrote.
Regards...
  • [vhdl]VHDL code[/vhdl]
